Old 08-17-2008, 08:57 AM
cameraman32 is on a distinguished road
best lubricant for worm gears
Hello, I've got some stainless steel / brass worm gear sets that go into a project I'm machining and I need to find a good lubricant for them. I can't constantly oil them (they are locked inside the device which is not meant to be opened regularly) and am wondering what will work best. Oil? Grease? What kinds?
I've been thinking that a teflon type grease, or other "space age" type grease might work well. There is so much friction in worm gears that the lubricant is probably quite important.
Thanks!
Stewart
Old 08-17-2008, 09:24 AM
Al_The_Man's Avatar
Nook Industries, which make acme and ballscrew jacks that use a worm gear, mention PAG-1 & PAG-45 grease for their units.
I have not personally sourced this type but a Google may unearth it.
Old 08-17-2008, 10:01 AM
X2cnc is on a distinguished road
I'd use ordinary 90wt hypoid gear oil from your favorite auto parts store.
Old 08-17-2008, 06:01 PM
Be sure whatever you use is formulated for use with copper alloys like brass and bronze etc. Many lubes will attack the copper alloys and pit them.
Dick Z
DZASTR
Old 08-19-2008, 07:44 AM
Thanks, i'll check out that Nook grease, and check if its approved for use with brass.
I was kind of hoping that someone would know of a perfect super low friction lube I'd never heard of.
Old 08-19-2008, 10:51 AM
You may consider the Royal Purple Synthetic mentioned in the Cone Drive list
www.conedrive.com/iandm/approvedlubrication.pdf
or check out http://www.machinerylubrication.com/...?articleid=169
Dick Z
DZASTR
Old 08-19-2008, 10:57 AM
HuFlungDung's Avatar
Moderator
Haas recommends Mobil SHC630 synthetic oil in their rotary indexers. Its not too viscous, but that suffices for worm gear drives that barely get warm while in operation.
Browning has a very heavy weight worm gear lubricant, IIRC, about 140 weight or more, pours like molasses at room temp. That would be for a really hardworking gearbox that gets hot.
It may be an interesting bit of trivia to know, but a single start worm has the highest coefficient of friction (resists backdriving), and more starts may prove to be better in some instances if speed reduction is the primary concern, where heat buildup may otherwise be considerable. Logically enough, a large diameter worm also has a higher circumferential velocity, so this may also generate more heat through both stirring action and worm velocity.
Old 08-19-2008, 11:37 AM
Is my suspicion that you are building something for moving an astronomical telescope at all valid?
If that is the case I think heat build up is the least of your worries, and I doubt you will be seeing very hig loads. Just about any general purpose lithium grease would probably be okay; even white petrolatum would probably be fine.
Old 08-19-2008, 11:48 AM
highspeedmazak is on a distinguished road
go to Napa and ask for the red grease I believe it is called #3 they will know exactly what you are looking for it is red grease that works great and can take just about anything. Check to make sure it is compatable with your metals but put it this way. It is the only grease that stands up to salt water for bearings. Not that you will ever have any water in it but just ask them they will explain how tough it is.
Old 08-20-2008, 12:05 PM
Stewart, I know this is off the subject. Just for your personal edification and possible application, You might want to look up "Gear Bearings" on NASA's available technology site.
John Vranich came up with a clever design for a combination of a gear and roller bearing. When used in a planetary gear set you can have near zero backlash, high torque multiplication, high efficiency in a small package.
OK, I'm guilty too. lol
Dick Z
DZASTR
  #11   Ban this user!
Old 08-22-2008, 05:52 PM
Stewart, Try this http://techtransfer.gsfc.nasa.gov//f...-bearings.html
Dick Z
DZASTR
  #12   Ban this user!
Old 08-22-2008, 08:27 PM
L.C. is on a distinguished road
might sound like b.s. but everthing your looking for is an oldtime secret . try it or at least try it after you've spent over 100. dollars and still nothing is worlking the way you want. MARVELES MYSTERY OIL .
Need A Quote- Worm gear and worm drive LEWENZ Employment Opportunity 3 04-27-2008 04:28 PM
WORM GEARS - Challenging but confusing! widgitmaster Mechanical Calculations/Engineering Design 28 09-19-2006 05:19 AM
Eliminating backlash with worm gears phantomcow2 Linear and Rotary Motion 3 01-27-2006 08:17 AM
Links to worm gears for 4th axis mocnc DIY-CNC Router Table Machines 3 12-23-2004 05:30 AM
worm gears, 4th axis senor J. DIY-CNC Router Table Machines 13 10-18-2004 11:53 AM
