Old 08-15-2008, 10:13 AM
Riverside192 is on a distinguished road
Bridgeport Romi Lathe Tailstock Adjustment
Does anyone out there know how to dial in the tailstock of these lathes? I have a .004 taper between centers in 12in. of travel. The manual doesn't say anything about adjustment. Thanks ahead of time.
Another Day in Paradise
Old 04-27-2009, 05:39 PM
minardsanders is on a distinguished road
Tailstock.
Does the tailstock have jackscrews one directly across from the other, down towards the base, make sure that you don't have the tailstock locked down when you adjust as this will break the slide, it should work as a push pull. let me know if this works. I will look at ours tomorrow. good luck. minard
Bridgeport/ROMI EZ Path Lathe mcsf General Metal Working Machines 3 12-13-2010 07:55 PM
Bridgeport/ROMI Engine lathe smittys800 Bridgeport and Hardinge Mills 19 04-14-2009 09:02 AM
Bridgeport Romi Password md63825 Bridgeport and Hardinge Mills 9 08-16-2007 05:53 PM
Need HELP on Bridgeport EZ-Path ROMI Lathe Michael Esch Machine Problems, Solutions , Wireless DNC, serial port 6 04-09-2007 10:38 PM
Manual needed to Romi/Bridgeport CNC lathe mgreene Bridgeport and Hardinge Mills 2 02-15-2005 02:20 PM
