Old 08-14-2008, 02:53 PM
mackeym is on a distinguished road
Additional Pseudo Axis
On a CNC lathe with servo spindle control, has anyone experimented with machining stock into non-cylindrical shapes by running the spindle at slow rpm's and moving the x-axis in/out as a function of spindle angular position. Are there any CAM programs that support such a feature?
I agree that it would require a spindle with high torque and fast and accurate x-axis movement.
Of course one can do a little with offsetting a part in a 4-jaw independant chuck, but the above concept has a lot more flexibility.
Old 08-14-2008, 04:22 PM
justin bowser is on a distinguished road
At work the Mazak I feed and push the button on stops rotating and moves in/out on the Z axis to broach a keyway inside of a bore. I don't see any reason why you couldn't do the same with the X axis, but I'm not a programmer...
Old 08-14-2008, 05:21 PM
samco is on a distinguished road
EMC2 has spindle synced motion that theoretically could do that. I don't think anyone has tried it yet. It would be a neat experiment.
http://www.linuxcnc.org/docs/2.2/htm...e-Synchronized
you would be breaking the motion into short x moves per partial revs.
a relatively high count spindle encoder imho.
This is a pretty complicated spindle synced motion gcode program.
http://jmkasunich.com/cgi-bin/blosxo...k/fusee-1.html
sam
Adding Additional Plugins to Mach3 GBBR2233 Tormach PCNC 3 02-11-2008 08:07 AM
RFQ - Additional CNC Machined Aluminum Part HighCaliber Employment Opportunity 9 03-08-2007 04:04 PM
Mach & Additional IOs aus-newb Mach Lathe 19 12-18-2006 10:07 AM
additional windows and menus hydrospin01 Haas Mills 3 11-02-2006 07:52 PM
Additional forum HuFlungDung General Metal Working Machines 6 03-03-2003 07:52 PM
