Old 08-14-2008, 12:04 PM
fastlanecafe is on a distinguished road
HORIZONTAL MILLS
Is there any particular advantage to a horizontal mill over a mill with tilting head? I have no experience with them, and don't see a lot of discussion on them. Are they sort of obsolete?
thanks
Old 08-15-2008, 02:40 PM
AR1911 is on a distinguished road
yes and no
thanks
Advantages? Several
Never need to tram the head.
Ideal for squaring up work.
Nothing better for slotting or saw slitting.
Great for cutting gears. People that build clocks own them.
Obsolete? Sort of. They don't make them anymore, with perhaps an obscure exception, because there is no demand. A vertical mill can do almost anything a horizontal can do. And a CNC machining center can do it all.
But if you have a manual mill, a CNC mill, a lathe or two, then you will see the utility of a horizontal. Plus, you can buy them dirt cheap. I gave $75 for my Burke #4. It's my 3rd mill.
Most people that have them leave them setup for the jobs they do best, or even keep them set up for one particular operation.
Old 08-16-2008, 02:00 PM
Plus they are far more rigid than glorified drill presses AKA "vertical turret mills" and generally have more power.
I agree with AR1911, horizontal mills are somewhat obsolete having been pretty much replaced by horizontal machining centers.
But if you have a horizontal mill in good condition, you're a lucky person. Keep it!!!
Dick Z
PS I'm prejudiced. The first machine I laid hands on was KT#2 horizontal milling machine in 1963.
DZASTR
Old 08-16-2008, 06:56 PM
And some horizontal mills also have a vertical head attachment. This makes it a very versatile machine.
Retrofit Lucas Horizontal Boring Mills...5" and 6" Banzai11 Mach Mill 0 06-17-2008 10:32 PM
horizontal spindle endgrainguy G-Code Programing 3 03-28-2008 09:44 PM
Horizontal Boring Mills Gkohl General Metal Working Machines 2 03-11-2008 08:06 AM
Face Mills intstead of end mills balal General Metalwork Discussion 8 07-01-2006 12:35 AM
