Old 08-12-2008, 10:38 PM
ryansuperbee is on a distinguished road
My CNC mill with mini lathe performing CNC lathe operations
Hey guys. I have a very simple setup here. I have a Smithy CNC mill 1240. And a regular mini lathe (microlux 7x14) With the mini lathe mounted to the table of my mill, and a lathe tool mounted to the neck of my spindle. I can perform CNC lathe operations, with no extra hardware! I simply use the mill's CNC capabilties to perform CNC lathe jobs! Check out my pictures and tell me what you think. And I am happy to answer any questions.
ID:	64785   Click image for larger version
ID:	64786   Click image for larger version
Name:	lathe cutting 003.jpg‎
ID:	64787   Click image for larger version
Name:	lathe cutting 004.jpg‎
Old 08-13-2008, 04:32 AM
student1616 is on a distinguished road
that's awesome.nice job.
so you used Z and X axes(of mill) to get the cnc movements of lathe right?
and if iam not looking wrong,your whole lathe setup is sitting on X axis.
that's a amazing setup you have there.
i would like to see a video of the machine.
Old 08-13-2008, 10:24 AM
Hey student1616. Yes, you have it right. The lathe is bolted to the table, which obviously moves in the X and Y axis. However, the only time I use the Y axis is to center the lathe cutting bit over the lathe. The Z and X axis are the only axis I use when I'm using the lathe. Programing is simple as well. I use my normal design software, I switch the "veiw" from top to front. Let's say I want to make a metal ball. All I have to draw is half a circle. And since I'm drawing in only the X and Z axis, the machine takes care of the rest. As far as a video goes. I need help as how to go about that. I have never uploaded a video before. So if you know how, let me know and I can upload it for you.
Old 08-13-2008, 10:50 PM
well youtube is ur best friend.
create an account and upload as many videos as you want.its free.once you upload it,share the link generated some thing like this
"http://www.youtube.com/watch?v=bvbArcGqkjk"
Old 08-15-2008, 02:44 PM
AR1911 is on a distinguished road
Wow!
That's thinking outside the box!
Old 08-19-2008, 04:55 PM
ironDigit is on a distinguished road
tormach just launched the exact same setup under the name : duality lathe ,implying a cnc and manualfunctions.
All i can add is : how come i didn't think of that ?
Finally CHIPS you can have as much as you can without the doc. complainting about your cholesterol.
Old 08-19-2008, 06:57 PM
Hi Irondigit, I am aware of the Tormach set up. The idea has been around for a while though if you think about it. When you look at the 3 in 1 machines, they work the exact same way. You just don't see them computerized. It is however, very nice to be able to remove the lathe when you are finished and then use it as a manual lathe. Check out my newest pictures! These are wheel centers made of aluminum, they fit perfect. And the finish is really nice as well.
ID:	65190   Click image for larger version
ID:	65192   Click image for larger version
Old 08-20-2008, 01:06 AM
CNC Pro is on a distinguished road
Bridgeport / mini-lathe combo
A friend of mine had an old Bridgeport CNC, and a mini-lathe. I suggested the same idea that you came up with. But I took a little different approach.
I considered the rigidity of the lathes’ cross slide, and the fact that the tool post allowed for easy tool clamping, centering, and the ability to do tool changes. So, instead of mounting the turning tool in the mills’ spindle, we instead mounted a piece of ground and polished bar stock in the spindle and fitted a simple plate to the top of the tool post with a corresponding bore to except the polished bar.
The cross slide needed to move freely, so the nut of the lead screw was simply removed/disengaged.
In operation, the polished bar was simply lowered into the plate on the tool post, and the mill moved the cross slide as programmed.
The end result worked very well, and the lathe was easily converted back to standard operation.
Tags
cnc, conversion, lathe, mill
Mini lathe and mini mill spindle? ZipSnipe General Metal Working Machines 3 10-15-2010 08:13 AM
Mini Lathe @ Mill @ Govdeals MoldMaker Mini Lathe 0 04-09-2008 09:40 AM
X2 Mini Mill & Mini Lathe - Cummins Tools ccsparky Benchtop Machines 0 12-19-2007 07:54 AM
Has anyone performed lathe operations on their mill? digits Benchtop Machines 7 02-18-2007 06:06 PM
CNC'd mini 3 in 1 lathe/mill Bloy2004 Mini Lathe 19 10-29-2004 03:59 AM
