Old 08-11-2008, 03:32 PM
ryansuperbee is on a distinguished road
I need sugestions on what lathe tool to use
I need suggestions on what lathe tool I need to make "barbed hose fittings" I have a CNC lathe, and I would prefer not to have to make a tool change. If you can suggest a lathe cutting tool that would be able to cut this piece out from start to finish that would be awsome. Keep in mind, I do not need the threads or the hex head. All it is, is the barbed part and a round flange at the end. Very simple part. I have basic lathe tools, I have already tried to cut out the part. One of the tools will cut the "barbs" but not the flange. And the other tool will cut out the flange but not the barbs. Like I said, I would prefer not to do a tool change. I have to make 5000 of these parts and a tool change would be costly.
Old 08-11-2008, 03:44 PM
Kipper's Avatar
Kipper is on a distinguished road
Not sure if this is helpful or not...A picture is worth....
Keith
Old 08-11-2008, 07:40 PM
cam1 is on a distinguished road
Hey: Just sharpen a HSS suare tool tool so that the angle on the tool end matches the angle of the barbs.Start at the end, and plunge the tool in to cut the first barb and retract in X.
Move the tool to the next Z, and do the same thing again repeat until all barbs are cut.
ps: check the other post for the info on the turn groove cutters.
regards
Can't Fix Stupid
Old 08-11-2008, 08:10 PM
Hey cam1. That actually sounds like a pretty good idea. The only problem I see with that, is that I have 5000 of these parts to make! I'm worried about consistancy. As far as the turn groove cutters go, I called ENCO and they said those are not capable of cutting side to side? I thought they looked very promissing. Maybe I should try to find more info on those.
Old 08-12-2008, 06:36 AM
Hi: Try a tooling OEM like Sandvik , you'll get better advice. A turn groove tool will make a finish cut for either RH or LH turning. I'd start the toolpath from the LH side.
regards
Can't Fix Stupid
Tags
lathe, tool
Need Help!- need sugestions on type of cutting bit to use ryansuperbee Mini Lathe 3 08-11-2008 09:39 AM
Any sugestions for this odd CNC project of mine? fearstyle DIY-CNC Router Table Machines 2 02-04-2008 02:35 PM
sugestions! watzmann CNCzone Club House 8 01-02-2007 04:05 AM
CAM software sugestions for Prototrak? rictek General CNC (Mill and Lathe) Control Software (NC) 1 03-25-2006 12:59 PM
New and need sugestions on a mini mill 691175002 Benchtop Machines 2 05-23-2005 01:09 AM
