Old 10-04-2004, 10:18 AM
*Registered*
CNCPlastic is on a distinguished road
Question on topping off coolant
I'm using a synthetic water based coolant and seem to lose about a gallon every week to two weeks presumably mostly to evaporation. My question is, are both the coolant and water evaporating or just the water? I wonder if my concentration of coolant is getting stronger and stronger if I'm losing mostly just water. Too bad they don't make a test device like they have for automotive antifreeze mix.
Old 10-04-2004, 10:27 AM
Gold Member
JFettig is on a distinguished road
depending on how much you got going on there and all, but it could be steaming out, then some coolant goes with it, I ususally just add water. At work in some of the lathes when they get run for full 8hrs on fast parts, I add 5-10gallons of water and a little bit of coolant a day. Its not too good for the health
They do make a testing device, It works quite nicely but I beleve its quite spendy. We have one at work I just guess at home
An easy way to check, is make it so you can feel the lube, but its not gooey. Right away when you first make a new batch, it shoudl be slightly clear, like you can see through a layer of it, but not through a lot of it. later it turns more white and stays white unless it gets oily and stuff.
Heres a pic of my early flood setup:
http://jfettig.wc101.com/cnc/flood1.jpg
Its just slightly thin but it thickened soon enough.
Jon
Old 10-04-2004, 12:41 PM
DAB_Design is on a distinguished road
The tester is called a refractometer. You can get them off ebay. Here's a quote out of one auction "CAN BE USED TO MEASURE THE CONCENTRATION OF ANY SUGAR BASED LIQUID OR METAL WORKING COOLANT." Not sure of exactly what it can be used with. But this auction is a 'Buy if Now' for $20. Measures up to 10%. auction # 3842846383. 8 still available.
Old 10-04-2004, 07:11 PM
sol sol is offline
Gold Member
sol is on a distinguished road
I know nothing about coolant but I do understand specific gravity and that is all that cheapo antifreeze gauges measure. Seems like it would be worth a try to just calibrate an antifreeze gauge with different concentrations of coolant mix.... only costs $1. 48
Coolant eating my paint. nervis1 General Metal Working Machines 5 12-05-2007 03:27 PM
How to avoid stinkin' coolant? ESjaavik Machine Problems, Solutions , Wireless DNC, serial port 28 10-10-2005 06:47 PM
Pics of my RF45 clone cnc conversion with flood coolant CNCPlastic Knee Vertical Mills 9 01-26-2005 02:02 PM
Question about applying coolant HawainPand General Metalwork Discussion 6 10-16-2004 10:02 PM
Coolant question Dan B General Metal Working Machines 9 03-19-2004 11:10 PM
