Old 07-31-2008, 08:15 AM
hotrob1 is on a distinguished road
Question Tamagawa Fa-coder
I'm working on a Mighty Comet with Mitsubishi MDS-A servos and Type HA80NT-E30 servomotors. The encoders are Fa-coder TS5170N11. I was getting a S03 servo alarm #50. It appeared a drive had went South. It was in position #2 (Y). I swapped with #3 (Z), Then Z alarmed out. I repaired the drive. I left it in Z. It wouldn't move, so I swapped it back with Y, nothing, and then swapped again. Now I have Y and Z down. I was wondering if the encoder (on Z) could be the problem and caused the known good drive to go bad. Does anyone have a pinout so I can test it? Any other suggestions? I have since repaired both drives but have not installed them yet due to the possible encoder problem.
Thanks in advance. (Machine Down)
Hotrob
Old 02-12-2009, 12:08 PM
MTWOLFEL is on a distinguished road
SAME PROBLEM HERE
DID YOU FIX THIS, I HAVE THE SAME KIND OF PROBLEM?
Old 05-25-2009, 11:27 AM
Thumbs up Yes.
Yes, I fixed this. First and foremost had a failed servodrive. I repaired it in house. Bottom line, the shaft was broken on the Y-axis servo motor. It was a little hard to find out that was the problem. All is well. Did you get yours fixed?
Hotrob1
www.aa-repair.com
Fanuc pulse coder pinout? Jonne Servo Motors and Drives 2 09-19-2007 02:15 PM
Tamagawa Seiki AC servos yoopertool Servo Motors and Drives 1 08-18-2007 11:12 AM
Unfit Pulse Of Pulse Coder Alarm Crashmaster Machine Problems, Solutions , Wireless DNC, serial port 2 04-23-2007 09:55 AM
Fanuc Pulse Coder Derek.C Fanuc 2 01-03-2007 08:24 PM
