Old 07-31-2008, 06:50 AM
JIMMY's Avatar
Moderator
JIMMY is on a distinguished road
Spindle Orientation
I have two yasda ybm640v cnc jig bore machines. I would like to orientate the spinde every 90 deg. Does anyone know what m or g code does this. I have a fanuc 16i-m control.
Old 08-03-2008, 03:23 AM
Paul_S's Avatar
Paul_S is on a distinguished road
If you can't index the spindle in more than one index location. You could consider setting 4 tools and holders at the 90 degrees.
For broaching on VMC we set addtional broaching tools for each 90 degrees as needed.
Safety - Quality - Production.
Old 08-03-2008, 09:36 AM
JIMMY's Avatar
Moderator
That is my second choice. I think that will be the way to go.
Old 08-03-2008, 09:57 AM
msantaji1 is on a distinguished road
i reply you after two day by trying on my machine your requirement
Old 08-03-2008, 09:58 AM
i reply you after two days by trying your requirement on my machine
Old 08-03-2008, 11:15 AM
JIMMY's Avatar
Moderator
Thank you
Spindle orientation StampCraft Haas Mills 5 11-10-2007 05:31 PM
Spindle orientation jimecv Daewoo/Doosan 4 11-09-2007 11:25 AM
16i / 18i Spindle Orientation... Sump Cleaner Fanuc 12 09-11-2007 07:46 AM
Will Mach do spindle orientation? KKutt Mach Software (ArtSoft software) 11 04-09-2007 05:52 PM
Spindle Orientation machinist39 Haas Mills 7 05-04-2006 08:58 PM
