Old 07-26-2008, 11:58 PM
toneV8 is on a distinguished road
Atlas horizontal MI mill
Can someone tell me where can I find instruction manual & illustrated parts manual for Atlas horizontal MI mill.
Old 07-27-2008, 04:38 AM
philbur is on a distinguished road
Have a look here:
http://www.lathes.co.uk/manuals/
- MA743 ATLAS MILLING MACHINE
Phil
Old 08-02-2008, 01:12 AM
I want to convert this mill to cnc.
I remove horizontal head and planned to put steel tube and router see pic.
What kaind acme ( trapezoidal ) screws and stepper motors ( torque ) to use.
Can someone recommend something.
Old 08-05-2008, 12:52 PM
Can someone help me with this.
I want start with conversion to cnc.
Old 08-05-2008, 02:50 PM
SpeedsCustom's Avatar
SpeedsCustom is on a distinguished road
It's not too complicated. You may want too make the head base from a casting. But thats more complicated.
I can see some big large steel beams being used and mounting everything together that way.
How do you plan on surfacing the cut part too have the new head mounted precisely?
-Jason
Old 08-06-2008, 01:45 AM
First I want convert 3axis to cnc and after I will see how to mount head together.
Now I need to know what kaind acme screws and stepper motors to use ( how much torque do I need for milling aluminium, brass, copper, plastic, wood). Is it Ok to use acme screw with more starts or acme screw with more starts is not good for milling aluminium.
Original acme screw is 1/2 but I will like to use 5/8.
Old 08-06-2008, 07:30 AM
ToneV8- I was thinking originally the same thing. I would keep the the head the way it is and modify that for spindle. Not the whole head assembly.
I would do 5/8 for CNC. As far as torque goes, I'm not sure in your case, because factors of your table weight, ratios all come into play. I'm not sure how big your mill will be, but I can see something being in the 700 Oz range...Just an estimation.
-Jason
Old 08-06-2008, 08:55 AM
Mike Horne is on a distinguished road
This fellow sells a good manual for the machine...
http://www.ozarkwoodworker.com/item/...gparts-manual/
This is interesting, as the base, knee, and table castings are often available from parted out machines on ebay.
I am surprised that more people haven't used these for a start point on a build.
The advise to use the head as is, with gearing to change the spindle speed is a good one. There are horizontal to vertical heads, that mount on the overarm available (but rare) already.
Luck
Mike Horne
Old 08-06-2008, 12:55 PM
The table is approximately 18''x4,5'' Z axis 6''
My mill is not bigger then Sieg X3 mill.
People who have Sieg X3 mill use X,Y axis 425oz for Z axis 600oz.
Can I use 425oz for my mill.
Old 08-06-2008, 06:23 PM
Oh yea, you should be fine. I thought it was much bigger.
-Jason
  #11   Ban this user!
Old 08-07-2008, 07:35 AM
For the motor lifting the knee and table, you may well want to go with a larger motor as the x3 does for the head.
Not many people are modifying this machine, as far as I can tell, so there is not going to be too much info out there.
So, if you convert to ball screws, you may be one of the first to do so.
I have one of these, mostly in pieces so I'll be following what you do
Mike
  #12   Ban this user!
Old 08-07-2008, 12:25 PM
There are no space for ball screws. Nuts are to big to put under table.
OKK horizontal cnc mill HMA460 bum1033 General CNC (Mill and Lathe) Control Software (NC) 1 05-20-2008 08:18 PM
B axis for horizontal mill OM nabil_elbadri Fanuc 3 11-16-2007 06:19 PM
Atlas Knee Mill Way Cover olf20 Knee Vertical Mills 0 09-26-2007 07:31 PM
Horizontal Mill Management Metalman97415 General Metalwork Discussion 1 08-15-2007 06:11 PM
Help with Horizontal Mill Programming MAX RPM Mechanical Calculations/Engineering Design 8 06-20-2006 10:18 PM
