Old 07-18-2008, 09:00 PM
joshuasalens is on a distinguished road
Question Might Comet VMC Madas 320 Control
We bought a used Mighty Comet VMC about 2 months ago. It was sitting in a warehouse for a while before we bought it. When we got it in the shop and all hooked up we had to reload the user and machine parameters. Everything works fine except that the machine is not sending a signal to the way oil pump to turn on, so it gives a "lube pressure fault" about every 15 minutes or so. The pump works manually, only in automatic mode will it give the alarm. My question is this, is there a parameter that I need to change to make the machine get the signal it needs? Perhaps a PLC timer parameter or a PMC parameter? I have done all that I can with the manuals that I have and it is very difficult to get an answer for Might USA. I keep getting the run around. If anyone has any suggestions I am all ears.
Thanks,
Josh
Need Help!- Mighty Comet/Viper 1000 - communication czech CNC Machining Centers 0 03-26-2008 04:40 PM
Comet 3KV Mill exploded view Jack F General Metal Working Machines 1 02-26-2007 10:08 AM
Comet Vmc-1000 ibeam CNC Machining Centers 1 02-05-2007 08:48 PM
comet vmc-1000 ibeam Test Forum 0 12-02-2006 09:57 AM
Just aquired first mill a Comet 3KV. Jack F Knee Vertical Mills 11 10-01-2006 12:41 PM
