Old 07-13-2008, 11:34 PM
henry_phd is on a distinguished road
new inexpensive automatic toolsetting device product
I've been developing an automatic toolsetting device for our own use in house and it works great and I'm ramping up to sell it.
Here are the particulars:
-self contained black box micro-computer driven and battery powered with a db-25 rs-232 connector on it
-interfaces with the rs-232 port of your CNC machine in DNC mode
How it works:
-has a bunch of dip switches, one for each tool you want to zero
-has a capacitance switch on the unit. when the metal part touches the top, the capacitance changes and this is detected
-uses DNC drip feed mode and sends a Z down command to the CNC controller through DNC mode then checks the sensor, if it hasn't hit yet, it issues another Z down command keeps going down until it touches
-once it touches, it tells the CNC controller to write the proper offset into memory, taking into account the thickness of the device (so offset 0 is your table 0)
-issues a tool change command until it cycles through all your tools
Benefits:
-no retrofit necessary
-no manually entering offsets, fully automatic
-uses standard G-code commands over RS-232 DNC drip feed mode
-inexpensive: right now pricing is set for $150 for 1 tool, $250 for up to 5 tools, $500 for 20 tools, $1000 for up to 100 tools
Right now I have configured for a Haas machine but any standard g-code can be programmed in the unit here.
Pics to follow soon.
PM me if you are interested and want to be kept updated/want to beta test.
Hurco bmc external device HELP tecko HURCO 4 03-26-2009 10:21 AM
need help with toolsetting macro parksteel General CNC (Mill and Lathe) Control Software (NC) 3 06-06-2008 09:15 AM
Unique 'HMI' Device! vacpress CNCzone Club House 0 12-22-2007 10:38 AM
Using a pc as a dro device.. hotponyshoes General CNC (Mill and Lathe) Control Software (NC) 4 02-21-2007 09:58 AM
modbus device Drew Machines running Mach Software 14 02-11-2007 01:59 PM
