Old 07-09-2008, 09:43 PM
csangster is on a distinguished road
First drill press (have tons of questions)
So I just purchased an old drill press.
It has seen better days and is not exactly what the seller advertised, so I feel like a fool.
The table isn't even perpendicular to the spindle, and there is no way to adjust it.
The PO basically took a heavy duty tabletop drill press, fudged together a 'table' and put a big tube in it to make it a stand-up drill press.
I feel like a fool because I should have looked this over with a fine tooth comb, but my tendency to 'trust' people blurred my vision until I got home and actually saw the condition of the drill press.
It has good bones (base, spindle, motor), but I am going to end up reversing all of the 'junk' that the PO put on it just so it will make nice true holes.
Now I have a few questions:
1) Where can I find pulleys for drill presses? The PO fudged a 3 slot pulley where a 5 slot used to be and it doesn't work right.
2) Where can I find a new drill press table? The one on there now is not original and is a welded together piece of junk.
3) Where can I find electric motor parts (switches, etc.)
Please advise on good locations for me to do some research.
I'll make a good drill press out of this one yet!
To make myself feel better, I am looking at this as a 'rescue' operation. Bringing an old drill press back to life.
Thanks in advance,
Chris
Old 07-10-2008, 07:57 PM
Kevin Taylor is on a distinguished road
Drill press woes
Do a Ebay search for the brand might find one that is dead or for part's . Email some Eq dealers and might find one for part's Is it a name brand Clausing , Wilton Do All Ect. or a hey jo from harbor freight might not be worth the time Good luck kevin
Old 07-11-2008, 03:20 AM
teamtexas's Avatar
teamtexas is on a distinguished road
I think I have an old set of pulleys from a drill press that I broke the spindle in a while back. What size bore do you need, I'll check to see if mine will work for you. I had the stand and table around here for years but sold it on ebay about 6 months ago. You can find the motor switches at Grainger or McMmastercarr.
Dan
CNC converted Drill Press compmedic General Metal Working Machines 23 01-21-2009 06:38 AM
Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press. Geof General Metalwork Discussion 47 02-01-2008 01:32 PM
brewed cnc mil using a drill press etc.. jpwatkins DIY-CNC Router Table Machines 4 04-13-2007 03:03 PM
Drill Press or Mill/Drill? cbcnc Benchtop Machines 2 03-05-2005 05:03 PM
