Old 07-07-2008, 06:40 PM
studysession is on a distinguished road
Playing on my lathe and wanted to share
It's been a while since I have posted. I was working with my lathe today and wanted to share.
Attached are pictures of a couple of rings I made. Please let me know what everyone thinks!@ I have never made a ring before - so this was my first atempt. Any advice would be appreciated.
A friend of mine asked me to make some antenna's. So figure I would do this to get me back used to using my lathe before making their stuff.
ID:	62740   Click image for larger version
ID:	62741   Click image for larger version
ID:	62742   Click image for larger version
Please check out my CNC blog
http://cncinside.com
Old 07-08-2008, 02:41 PM
ironDigit is on a distinguished road
maybe i may answer your question with mine.
how do yall make rings fillet on both in and outside?like engagemant and wedding rings?
thx in advance.
nice work by the way good lukk with the antennas.
Finally CHIPS you can have as much as you can without the doc. complainting about your cholesterol.
Old 07-08-2008, 07:48 PM
To size a ring would be hard for me. I bored out the center to the size I needed and then trimmed the outside the way I wanted after. I would not know how to re-size anything.
This is aluminum - I think they heat up the metal and stretch or take away to re-size a ring. Not 100% sure but aluminum take a lot higher temps to melt than gold or silver.
Thanks for the compliments.
Old 07-08-2008, 09:01 PM
jkeyser14 is on a distinguished road
Any one of four ways (excluding casting cause that's what the jewlers use).
1) radius attachment (also commonly referred to as a ball turning attachment)
2) grind the fillet shape into a piece of HSS and use that to profile the piece
3) good old fashion hand file
4) cnc lathe can easily do curves
-John
http://www.engineeringhobbyist.com
Old 07-08-2008, 11:25 PM
d.dixson is on a distinguished road
Re-sizing mandrel... they have ring sizes printed/stamped on them and a press ring. You slide your ring onto the mandrel, slip on the press ring and tap with a mallet until your ring is on the mark for the size you are after. No heat involved. Unless you are trying to make it smaller... at which point, you make a cut and force the ends together. Solder together again and slip back on the sizing mandrel. Size to fit...
Old 07-09-2008, 06:33 AM
PEU's Avatar
PEU PEU is offline
PEU is on a distinguished road
A resizing mallet would work in a soft metal like gold, Im not sure if you can resize that way an aluminium ring. Yesterday I made a titanium ring for my wife, Im 100% sure a mallet would be of no use in it, she asked to make it a tiny bit larger ID, I will put it in the lathe again.
The ring OD is exactly 19mm (almost 3/4") so having an ER40 collet for that size was a real saver.
Old 07-09-2008, 12:56 PM
nice work,
but yet i can't grasp how to decently clamp a ring in a lathe to make both id and od fillet or perhapse completele round shaped like a donut....hmmm yeah maybe i should a asked how do you turn a donutshaped ring ?
thx in advance again.
Old 07-10-2008, 11:30 PM
larry53 is on a distinguished road
You might want to play around with a knurl on the ring before you bore the hole. This will give you a different look
Wanted to buy CNC Lathe Florida TWyatt9 Want To Buy...Need help! 0 03-17-2008 01:36 PM
Special Lathe Wanted MrGrunzy Mori lathes 1 12-15-2007 01:21 PM
Opinions wanted on lathe chucks protrxrptr17 General Metal Working Machines 8 11-06-2006 09:23 AM
ok share the knowledge share the wealth...huh...right oaktree444 General Metalwork Discussion 9 10-18-2005 04:54 PM
Wanted Lathe Jobs MBG Employment Opportunity 1 05-25-2005 08:33 PM
