Old 07-02-2008, 06:32 PM
jerry1122 is on a distinguished road
Drilling copper
Hi all, I have just started on cnc zone so here go's.
I need to drill a .094 or # 41 hole 1'' deep in copper can you get me started on speeds and feeds thanks.
jerry1122
Old 07-03-2008, 03:20 AM
gsrmmeza is on a distinguished road
This is what Chicago Latrobe recommends:
RPM = 3.82 X SFM / drill diameter
SFM = 140 - 200
FR = RPM x IPR
IPR = .001 - .002
RPM = Revolutions Per Minute
SFM = Surface Feed Per Minute
FR = Feed Rate
IPR = Inch Per Revolution
RPM = 3.82 X 140 / .094
RPM = 5689
FR = 5689 x .001
FR = 5.689
I would use a HSS Tin coated drill.
You could also call Chicago Latrobe Technical Information 888-434-4311
Old 07-03-2008, 06:35 AM
Drilling copper
Thank you I am going to give it a try.
Old 07-04-2008, 07:06 PM
fatal-exception's Avatar
fatal-exception is on a distinguished road
Milk as a lubricant apparently gives an excellent surface finish. One of those old trial and error things I read in a book somewhere.
Paul
Old 07-04-2008, 07:45 PM
youngjim is on a distinguished road
I read also about grinding the cutting edge square. It might be worth a search.
No time to do it right, plenty of time to do it twice.
Old 07-06-2008, 01:33 PM
Drilling copper
I have it drilling good now 1600 rpm and 30.5 feed.
I need to run 8,000 per month so will see how it goes.
Thanks jerry1122
muskegon mi.
drilling copper jeremyinnys General Metalwork Discussion 9 08-25-2011 11:08 PM
copper? bowhunter General Metalwork Discussion 13 04-26-2007 12:41 PM
drilling and drilling cycles tutorial wmorre General Metalwork Discussion 0 10-18-2006 06:30 PM
milling copper (99%) nervis1 General Metal Working Machines 3 09-26-2004 06:34 PM
what tip to use for copper? HawainPand General Metalwork Discussion 1 09-22-2004 03:30 AM
