Old 07-02-2008, 07:36 AM
guru_florida's Avatar
guru_florida is on a distinguished road
Aluminum cutting head, sherline maybe?
I am almost complete my machine and I would like to buy my cutting head now. I will mill aluminum a lot, but also plastic, machine wax, and sometimes wood. I would like a ~1k-9k RPM cutter. I am in the US, so also collet/spindle type that's standard here. I could really use some help with what is good and economical.
I was looking at the Sherline 3307 for $380:
http://www.sherlinedirect.com/index....Product_ID=165
I am not sure how well this will cut aluminum or what its feedrate/rpm is capable of thru aluminum. I would hope its not a slow feedrate.
Would I get the Sherline only to want more? What other options are out there? I cant find much. I don't want a standard router due to the typical runout/chatter problems. I searched here, google and ebay.
My avatar shows my cnc table. Lots of plate space for the headstock. The cutting table is 16"x16", the tower spans are 3"x3", if that gives you an idea about the size. The mill is 80Lbs or thereabouts.
Thanks,
Colin
Old 07-02-2008, 11:01 AM
sergizmo is on a distinguished road
It doesn't specify the taper. Most are Morse 1, but there are some of the "industrial" Sherline spindles that are ER16. As it doesn't specify I'd assume it was M1, but you may want to contact Sherline to make sure.
When cutting aluminum on my Sherline: 3/8" two flute end mill running 2,800RPM (max on standard spindle), .025" DOC, 8IPM with about 45-50% stepover. Much more than that and you may want to look at other options.
There is a company called Lane Manufacturing that makes a variable speed motor and speed control unit for the Taig (without spindle) for $195. This would be more powerfull than the Sherline motor. Add an ER16 Taig spindle, and it could be a higher powered alternative to the Sherline.
http://lanemfg.com/default.aspx
www.taigtools.com
If you really want to step it up in terms of a spindle there is a company called Finley that makes some fine looking spindles. There are 10mm and 13mm max capacity belt driven versions. I think the smaller one is about $900 and the larger $1300. This is just for the spindle.
http://www.finleyspindles.com/index.htm
Good luck,
Serge
Old 07-02-2008, 12:05 PM
That Lane motor controller seems like it would fit nicely on my machine. I looked into the Taig Spindle too.
Thanks for the info. I dont think I can afford to buy a heavy spindle like the finleys. I think I might get there later when the machine starts paying for itself. At this point, I've cut very little thats useful, and spent gobs of money. I think the Taig or sherline will work for now if no one else has any alternatives. People seem to be happy with thier Taigs and Sherlines, a lot of hobby machinists have one or the other.
G-Code for bevel cutting head Franz Grueter General CNC (Mill and Lathe) Control Software (NC) 1 02-17-2009 07:21 PM
Cutting Aluminum bossfrog DynaTorch 8 07-07-2008 09:21 AM
First G10 CNC Cutting with sherline 5400 genexis Benchtop Machines 0 06-27-2007 10:42 PM
Cutting Aluminum darylprice DIY-CNC Router Table Machines 7 07-03-2006 10:51 AM
has anyone seen an aluminum table for an old J-head bridgeport mill? xhardwaremanx Bridgeport and Hardinge Mills 2 11-19-2005 02:06 PM
