Old 09-17-2004, 05:34 PM
nMotion is on a distinguished road
Kitamura Spindle Questions
I have a Kitamura 12,000 rpm spindle with a BT 30 taper. I'm not sure exactly what model machine it came from. I am planning on using it in my CNC mill. I have a couple of questions:
1) I can't figure out how the tool holder actuator works or if it is even present. I can see the tool retention "fingers" but I can't find where an air line would attach to the spindle. The very top of the spindle has about a 3/16" hole in the shaft?? I would like to figure out how to get this thing working without taking the whole thing apart!
2) I believe that the spindle is cooled with an air/oil mixture and was told that I need a "lubricator". What type of lubricator should I look for and what type of settings should I have for air/oil ratio, pressure etc?
3) Does anyone know what type of pull stud a Kitamura BT30 should use?
Thanks!
Sherline spindle to 30k RPM -- am I crazy? nicad General Metal Working Machines 21 11-17-2010 02:57 PM
CNC Controlled Spindle motor speed control gregmary General Electronics Discussion 13 02-27-2009 07:01 PM
Gilman box spindle pics Swede Benchtop Machines 5 03-30-2005 09:41 AM
Small spindle selection Swede General Metal Working Machines 22 02-14-2005 11:57 AM
2.2KW Allen Brad. Spindle motor? GalaticDan Servo Motors and Drives 2 02-02-2005 11:46 AM
