Old 06-28-2008, 10:25 AM
mikehg1 is on a distinguished road
Carbide insert designations
I've searched the web with no definitive answer on this. I was wondering if there is a standard to letter designators for carbide inserts? For instance I have a Dolfa 2" - 3 insert face mill that uses SPC, SPG, or SPU42 inserts. Is there any rhyme or reason to the letters used here?
Old 06-28-2008, 06:22 PM
CarbideBob is on a distinguished road
S = square
P = 11 degree side clearance ( sometimes 10 degrees )
C = +/-.0005 IC (size of the square), +/-.001 Thickness
..... G = +/- .001 IC, +/-.005 Thickness
......U = +/- .005 IC, +/-.005 Thickness, unground periphery - not recommended for milling
4 = .500 IC dim (Inscribed circle in 1/8ths of an inch)
2 = .125 Thick ( Thickness in 1/16ths of an inch)
You are missing the last number which specifies the radius size in 64ths. #1=.0156 rad, #2=.0312 rad. etc.
This is an ANSI standard designation and is found in all the mfgs catalogs.
I believe CarbideDepot also has this on their website.
Bob
You can always spot the pioneers -- They're the ones with the arrows in their backs.
Old 06-28-2008, 06:43 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
T= Triangle
I had a chart for Iscar Inserts at work, maybe they have a chart on line?
Free DXF Files - Vectorink.com - myDXF.blogspot.com
Old 06-28-2008, 09:46 PM
Thanks a bunch. Thats just the kind of info I was looking for!
Mike
Old 06-29-2008, 03:22 AM
Kipper's Avatar
Kipper is on a distinguished road
I've had this for a while...May be helpful?
Keith
Old 06-29-2008, 10:08 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
I didn't look at the above zip but here is a link http://www.kbctools.com/can/Navigati...fm?PDFPage=247
www.integratedmechanical.ca
Tags
carbide inserts
Tool Insert Help Cartierusm General Metal Working Machines 2 11-21-2007 08:05 AM
Looking for Insert. Al_The_Man General Metalwork Discussion 10 08-02-2007 10:27 AM
Insert for 62 Hrc M-man General Metalwork Discussion 5 02-13-2007 03:09 PM
INsert Molding PC7 Moldmaking 3 04-15-2006 06:56 AM
Identify this insert Cold Fusion General Metalwork Discussion 7 08-27-2005 09:56 PM
