Old 06-17-2008, 10:07 AM
chrisryn is on a distinguished road
Lathe tool turret problem
I had an operator crash the tool turrent into the spindle while running. I believe it knocked my turret out of alignment because nothing is cutting on the correct edge of the insert. I got maintenance involved they told me to check the alignment if its off they will fix it. Well I don't know how to check the alignment. Can some one explain how to do that.
Thanks in advance.
Chris
No matter how good you are, there is always someone better!!!
Old 06-17-2008, 12:01 PM
Guldberg is on a distinguished road
So after a crash maintenance doesn't even bother helping you out measuring and realigning it?! Maybe you need a new maintenance department instead :-D
Old 06-17-2008, 12:15 PM
Originally Posted by chrisryn View Post
....I got maintenance involved they told me to check the alignment if its off they will fix it. Well I don't know how to check the alignment. Can some one explain how to do that.
Thanks in advance.
Chris
Put a boring bar in the turret and a dial indicator in the chuck and check whether the bar is on the spindle centerline. Normally you can adjust to spindle centerline just by using the X axis; if it has been knocked out of alignment you will find position where it is centered in the X direction but is above or below center ninety degrees to the X axis (up and down).
I kinda agree with Guldberg's comments about your maintenance people.
Another thing you will need to check is the head alignment. Before re-aligning the turret I suggest gripping a length of stock in the chuck and packing up a tool until it is cutting okay. Then turn at least a 6" length and check for taper, this will show if the spindle alignment is off. You must fix the spindle first otherwise all you will do is re-align the turret to a spindle that is wrong, then when you fix the spindle alignment you have to go back and do the turret again.
Old 06-17-2008, 01:10 PM
I understand the part about checking the head first and how to check the head. You confused me on the tool turret.
Old 06-17-2008, 02:02 PM
If the turret is correctly aligned then it will be possible to get the centerline of a boring bar inline with the spindle centerline just by moving th X axis.
If the crash did move the turret it will be rotated out of alignment so the boring bar centerline will be above or below center on the spindle.
No matter how you adjust the X axis position you will never get the boring bar and spindle on center, but at a certain point on the X axis you will find your dial reading goes to a maximum at one position in the spindle rotation, and to a minimum a 180 degrees away from this, and at the 90 degree positions either side of the maximum and minimum positions you will have the same reading.
Converting my Engine Lathe to an 8-Station Turret Lathe! widgitmaster General Metal Working Machines 93 10-31-2011 03:27 AM
Newbie- Need Turret Tool Clamps Rwolfejr Want To Buy...Need help! 0 03-06-2008 02:42 PM
Tool holders for Daewoo lathe turret? Chuck Reamer CNC Tooling 1 01-01-2008 06:14 AM
Lathe Tool Turret mikemill General Metal Working Machines 2 12-15-2007 09:57 AM
SL 10 turret problem PBMW Haas Mills 1 08-15-2006 08:51 PM
