Old 06-13-2008, 07:05 AM
seanreit is on a distinguished road
What is needed to drive these?
I see these from time to time on Ebay, and have always wondered what type of controller is required to drive these. Thanks in advance for the help:
http://cgi.ebay.com/ws/eBayISAPI.dll...E:B:SS:US:1123
Old 06-13-2008, 08:29 AM
Al_The_Man's Avatar
They require a BLDC, Brushless DC Drive, you would need the information off the motor to size the drive correctly.
There are many manuf. out there, also model depends on what type of signal you are using to drive it.
Old 06-13-2008, 08:34 AM
Are they terribly expensive? Can you show me an example of one with a best guess estimate based on what you see in that auction? I'm just trying to get a rough idea.
If I have a ballscrew, stepper motor driving x and y, could this unit be used to drive a Z axis? Not sure if you can mix and match, but thought it would be worth asking.
Old 06-13-2008, 08:50 AM
Al_The_Man's Avatar
You didn't mention what controller you are using, but analogue +-10v are the most common, if you want step/dir then I believe Granite devices make a controller for them.
On ebay, the analogue come up as Advanced Motion, Copley or Aerotech, for a few.
Again, it depends on motor size also.
Most controllers allow you to mix and match types.
Simple, 3 Axes with Dual Drive/Motor (per axis), hardware splitter drive Interface. kreutz Stepper Motors and Drives 3 07-03-2008 06:57 PM
Belt Drive - advice needed Pat2000 Linear and Rotary Motion 11 11-01-2005 08:11 AM
Drive selection help needed DJB282000 General Electronics Discussion 8 07-04-2005 04:57 PM
Cheap 0 Clifton and servo drive selection (advice needed) Konstantin General Electronics Discussion 4 04-14-2004 10:21 AM
