Old 06-12-2008, 02:08 PM
tpehlke is on a distinguished road
What is a36 metal?
what are the statistics like sfm, and hb?
thanks,
timbo
Old 06-12-2008, 04:22 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
That is entirely dependant on your tooling and set-up.
Lets say 250 SFM for HSS and 450 SFM for Carbide.
I don't know what you mean by hb?
www.integratedmechanical.ca
Old 06-15-2008, 03:01 PM
Skeeterd5150 is on a distinguished road
maybe he meant hardness brinell?
Old 06-16-2008, 10:42 AM
youngjim is on a distinguished road
Or potentially Hardness, Rockwell B? Hmm.
No time to do it right, plenty of time to do it twice.
Old 06-16-2008, 12:05 PM
Yes That is what I meant. I have some insert drills that ask for that.
Thanks,
Tim Pehlke
Old 06-16-2008, 01:25 PM
A36 steel; hardness??? Softness is more like it, as in cheap cheese.
Although sometimes you can get burnt on this stuff, or your tool can, because occasionally you run into inclusions that are very hard. The scale on the surface can also be hard and the first pass should be 30 thou or so; trying to take a very thin skim can take the edge off the tool very quickly.
Old 06-17-2008, 06:54 AM
DareBee's Avatar
I have never had inclusion issues with A36. I do with Blackmax all the time. Inclusions or lack thereof is the only reason I ever use A36 over Blackmax.
Generally speaking I am a 44W guy where HR plate is involved.
Old 06-19-2008, 12:48 PM
KyleH2's Avatar
KyleH2 is on a distinguished road
If you ever need to know the properties of a metal you can check out MatWeb Usually it will give you the Brinell hardness and say Low Carbon Steel and from that you can calculate about what you need.
http://www.matweb.com/search/DataSheet.aspx?MatID=14016
I too have had problems with surface finish machining A36.
Old 09-26-2008, 01:04 AM
AppEng is on a distinguished road
Carbide or HSS? Run 450sfm with carbide f you want to fall asleep while machining. It is generally a very easy material to machine, and can be ran upwards of 1000sfm in face milling very successfully depending on feed/tooth with a good cutter and carbide grade for example. A36 plate is a common structural steel, that is relatively soft, but can have scale and inclusions, and is commonly torch-cut, which can leave a heat-affected zone. The trick there is not to baby it- just get under the scale and pour the beef to it. Good finishes are easy to obtain. Face/side milling, boring, turning???
Old 09-26-2008, 01:55 PM
littlerob's Avatar
littlerob is on a distinguished road
If you are using an insert drill I think that is where you will fight it, It is so soft the chip doesn't break, like copper, where if you use high speed steel you would peck at it. I have been successful with an insert drill it's just a little scary. MTC Robert
  #11   Ban this user!
Old 09-26-2008, 11:55 PM
Scary? No. Just push the feed harder...it's a soft material, but the chip WILL break, or you're doing something wrong. If you're insert drilling and don't have the HP/Torque to push harder than you are now, try an outboard insert with a lighter edge that will break tighter and draw less HP.
  #12   Ban this user!
Old 07-12-2009, 06:43 PM
Ed from NY is on a distinguished road
Just FYI, according to eMachineShop Brinell for A36 is 140.
Updating this old thread because that is where Google sent me when I searched for "A36 brinell"
Scrap metal recycling - American scrap metal recycling Ascrap2003 Want To Buy...Need help! 0 05-05-2008 03:21 PM
Newbie- Which red metal? steele General Material Machining Solutions 7 02-25-2008 09:27 AM
First cut in metal sickpaint Syil Products 0 12-25-2007 06:17 PM
Build cnc router without linear ball bearings ?? Flat metal on flat metal with lube ? vroemm Linear and Rotary Motion 7 08-16-2007 12:26 PM
where do you get your metal? annihilator DIY-CNC Router Table Machines 18 11-24-2004 04:28 PM
