Old 06-11-2008, 12:40 PM
zanellan is on a distinguished road
Boring Out Jaws
Hi, this is my first post and i would like some help. Could someone please go through the basic steps of boring out soft jaws on a CNC machine please. All help will be gladly welcomed!
Old 06-11-2008, 02:22 PM
Did you try searching using your title as a search string? This has been discussed a few times. Briefly it is a case of have your jaws held at the approximate mid point of their travel in a manner that loads the jaws in the same way they will be loaded in use. One way to do this is put tight fitting pins in the counterbore on the outer bolts and have a ring that is gripped by these pins acting as jaws. The ring has to be of the correct diameter so that the jaws are midway in their travel as I mentioned. It is possible to buy adjustable rings, actually they are more like a three lobed cam, to get the correct size.
Then bore the jaws to a thou or two smaller than the stock you will be gripping (inches of course, I guess for metric it would be a hundredth of so smaller).
Old 06-11-2008, 02:33 PM
LeeWay's Avatar
LeeWay is on a distinguished road
Here is an image of the type ring Geof described.
http://cgi.ebay.com/12-BORING-RING-C...QQcmdZViewItem
Lee
need flat jaws? TURN ME Okuma 1 04-28-2008 07:04 PM
6 inch jaws DSL PWR CNC Tooling 0 11-12-2007 08:24 PM
Boring soft chuck jaws for ID holding? SRT Mike General Metalwork Discussion 9 10-31-2007 10:52 AM
Macro for Boring lathe Jaws - Fanuc 21i-T CNCSport General Metal Working Machines 5 10-17-2007 05:07 PM
