Old 06-11-2008, 11:01 AM
smellyfeet is on a distinguished road
Coolant, mixing in more water
We use Castrol Hysol EP soluable and after a couple of weeks of evaporation and topping up the refractometer reading goes off the scale.
I was told by Castrol and the rep that you shouldnt top off with neat water.
Is this true? Does anyone have any experience with this?
Thanks.
Old 06-11-2008, 12:05 PM
Chuck Reamer's Avatar
Chuck Reamer is on a distinguished road
Absolutely, the coolant stays as the water evaporates off. My coolant rep was telling me one of his customers added 35 pails of straight water in a month, with only a couple of mixed coolant. You will need to add water more than mixed coolant in some machines.
I have a mill with a 7 gallon reservoir and I add with about 1-2% coolant and it keeps the refrac reading at around 5%.
Live free or die
Old 06-11-2008, 12:17 PM
Gold Member
Caprirs is on a distinguished road
That is correct. Generally, only the water evaporates. The coolant tends to stay. Think about it like salt water. The salt does not evaporate with the water (well a little does). If all the water evaporates, only the salt will remain.
Here in Arizona where the summer temps are 100*+ and the humidity is 5%, I can replace 5 gallons of water a day in the machine. I also replace 1.5 gallons in me.
Old 06-11-2008, 12:29 PM
Originally Posted by Caprirs View Post
...I also replace 1.5 gallons in me.
Make sure you check with the refractometer so you don't overdo it.
Old 06-11-2008, 01:34 PM
Gold Member
What is considered ideal on the Brix scale?
Old 06-11-2008, 03:32 PM
Geof; As you know you can rehydrate with with copious amounts beer. It has been my experience that the liquid level is self regulating. As I've gotten more experienced (older) I do the regulating thing more often. lol
Dick Z
DZASTR
Old 06-11-2008, 03:41 PM
Dick Z
We`are probably going to get lambasted for hijacking.
I find in hot weather, with the type and strength of beer I like to drink, intoxication tends to precede rehydration. You need weak Australian or New Zealand weasel **** for successful rehydration.
Old 06-30-2008, 06:39 AM
Sorry, I have been on paternity leave for a couple of weeks. Thanks for your answers, I have just topped up using water and got the refractometer readings back on the scale (roughly 5%). One thing I found immediately is that the coolant clears from the windows more quickly now so the ops can see whats going on. Hopefully this will save us a few pennies too as the oil price rockets..... Thanks again.
Smelly.
Water Soda mixing ratio? Normsthename CNC Plasma and Waterjet Machines 1 01-05-2008 06:28 PM
Water-based coolant/lube use and handling jim_stoll Benchtop Machines 6 11-13-2007 12:49 AM
Water transfer techniques for water table? Knut CNC Plasma and Waterjet Machines 3 02-02-2007 09:52 AM
Mixing servos and steppers? Corvus corax Servo Motors and Drives 2 12-05-2005 01:20 AM
mixing different motors? koslaz Servo Motors and Drives 2 06-12-2005 01:54 AM
