Old 09-07-2004, 06:38 PM
Fudd is on a distinguished road
Multi-start Thread on a Fanuc OT controller
What is the best way to program to cut multi-start threads on a lathe with a Fanuc OT controller on it?
Thanks,
Scott
Old 09-07-2004, 06:52 PM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
Fudd .. er Scott,
As far as I know, (and I could be wrong) you can't program multi start threads on a Fanuc OT control...
If you or anybody figures a way to do it..please let me know.
Old 09-07-2004, 07:05 PM
duluthboat's Avatar
duluthboat is on a distinguished road
If the controller won't let you idex the start point, you will have to shift Z zero to give you the right start point or index the part.
Gary
Old 09-08-2004, 04:40 PM
Zep Zep is offline
Zep is on a distinguished road
multi start thread program for 0t
thread would be done using a z value shift and two thread programs
similiar as to what follows
G00 X1.1 Z.1
G76 P010060 Q20
G76 X.9 Z-1.0 P060 Q250 F.25
G00 X1.1 Z.225
G76 P010060 Q20
FEED OF .250 WITH A .125 SHIFT between canned cycles will start second thread 180 degrees from start of first thread
this will work if your 0T is set up for two line canned cycles.
program will probably vary depending on programming style but the concept is the same. two thread programs using a feed of 2x your required pitch
with a shift of 1 required pitch ie. this program would result in a 1 inch 8tpi two start thread. (minor dia. is not to spec. just an example)
Old 09-11-2004, 06:54 PM
Thanks Guys. That worked like a charm.
Thanks,
Scott
Old 09-11-2004, 07:02 PM
wms's Avatar
wms wms is offline
Moderator
Thanks Zep and Gary too.
Old dog learns new trick.
Old 09-11-2004, 07:28 PM
Zep Zep is offline
not bad for a chip sweeper eh!
Old 06-13-2011, 09:45 PM
khamul2000 is on a distinguished road
Multiple start thread 4TPI 4 Start
can any one tell me if i got this right. i have to make a new thread on a head for one of our deep hole drilling machines. The thread is 4 TPI 0 TPF 4 start and 1.75" long. when i normally program a thread cycle i use a G92 command. I believe what i need to do is instead of running at a feed rate of .25 for a normal 4 TPI thread. I increase the feed to 1.000 and run the thread cycle and then off set the my z by .25 three more times in which case would give 4 start points, 1 every 90 degrees, and 4 TPI?
EG:
Z1.25
G92 X2. Z-1.75 F1.
X1.9
X1.8
X1.7
X1.6
Z1.
G92 X2. Z-1.75 F1.
X1.9
X1.8
X1.7
X1.6
Z.75
G92 X2. Z-1.75 F1.
X1.9
X1.8
X1.7
X1.6
Z.5
G92 X2. Z-1.75 F1.
X1.9
X1.8
X1.7
X1.6
I believe that would work would it not?
Fanuc 18i-M controller Wjman Machine Problems, Solutions , Wireless DNC, serial port 9 10-01-2010 12:02 PM
DNC Feeding your Fanuc Controller Gerry Newe Fanuc 5 07-06-2010 09:15 PM
Parameters No. for file transfer on a Fanuc O-mate controller Niall Fanuc 8 06-03-2009 08:14 AM
GMF Fanuc L-100 Robot R-F controller whiteriver Fanuc 5 01-28-2005 10:16 AM
Anyone here ever used a Fanuc Position Mate controller? Tarak Fanuc 1 10-18-2003 08:34 PM
