Old 06-04-2008, 02:33 AM
djnbig's Avatar
Machining Monster
djnbig is on a distinguished road
Need some honest opinions on this CNC VMC.
I'm considering this for my next purchase, i want some honest opinions from thoes that either experienced it first hand, or anyone who would like to just comment on the general specs. This is going to be machining aluminum motorcyle parts in average quantitys. Ranging from 2"x2" to 8"x10" in batches of 100 - 2000 peices.
It's made by Modern Tool, not sure where exactly.
MODERN Model MM-430 Mini Vertical Machining Center
Here's a link to the PDF.
http://www.moderntool.com/new%20pics...n%20MM-430.pdf
Here's a link to some pictures,
http://www.moderntool.com/new%20pics...Mini%20CNC.jpg
http://www.moderntool.com/new%20pics...%20control.jpg
http://www.moderntool.com/new%20pics...%20spindle.jpg
Price listed is $49,000 CAD. The 4th axis is another $21,000, which seems quite high to me?
Some input would be highly appriciated ..
Some specs below incase you can't view PDF.
Thanks,
Jer
Code:
C/W: Fagor 8040MC CNC Control
SPECIFICATIONS:
Table:
Table Size        35.43” X 16.14”
Distance Table to Floor                                                        32.28”
Table Weight Capacity                                                         770 lbs.
Table T Slots (4)        .625” X 3.93” Centers
Travel:
X Axis        29.92”
Y Axis        16.93”
Z Axis        15.74” (Std.) 18.11” (Opt.)
Spindle:
Taper        ISO 40
Spindle bearing I.D.                                                              2.36”
Spindle Speed        8,000 RPM
Spindle center to guide way                                                18.89”
Spindle nose to table surface                                              4.01” – 22.12”
Ballscrew:
X Axis        Dia. 1.259” X P8
Y Axis        Dia. 1.259” X P8
Z Axis        Dia. 1.259” X P8
Linear Guideways (Ball) X/Y/Z                                             1.377”
Modern MM-430 CNC Page 2
 Motors:
Spindle        7.3/10 HP
X Axis        2.84 nm
Y Axis        2.84 nm
Z Axis        8.34 nm
Coolant pump        Ό HP
Automatic Tool Changer:
Pockets        16
Tool Taper        BT#40 / CAT#40/DIN69871
Max tool weight        11.88 lbs
Max tool diameter        3.5” (using all pockets)
Performance:
Rapid traverse:        944 I.P.M.
Positioning accuracy                                                            +/- .00019”
Repeatability        +/- .00019”
Dimension &Weight
10.5 ft x 9.5 ft x 8 ft
Basic Machine        7500LBS
Complete With:
Fagor 8040MC CNC Control, DNC Software,  Coolant System, Work Lamp, Full Enclosure, 16 Tools A.T.C.,  CSA Electrics, Manuals and maintenance tools.
PRICE . . . . . . . .. . . . . . FOB CALGARY/ EDMONTON  . . . . .  $49,900.00 CDN.
Options
4th Axis Table………………………………………………………..$ 21,500. 00
Old 06-04-2008, 04:37 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
I really like the Fagor control although the 8040 has been obsolete for a few years now. The 8055 is the new improved version.
I also would never buy a VMC without rigid tapping.
Specs look good.
4th axis price is about $6000 high IMO
www.integratedmechanical.ca
Old 06-04-2008, 11:43 PM
Cory is on a distinguished road
$21,000 is a ripoff. My Haas was ~$11,000 for the 4th axis interface, 6" rotary, and chuck.
I wouldn't buy it. Look at a RoboDrill. Perfectly matches your small part sizes, and is blazing fast. As well as being cheaper.
That looks like a rebadged Milltronics machine. I've heard some complaints about them-mainly that their tables are so soft you can drop a part on them and ding the table.
Old 06-05-2008, 05:38 PM
djnbig's Avatar
Machining Monster
I contacted Modern and they tell me the Fagor 8055 IA Control is being used now. They also tell me the unit indeed has ridgid tapping.
I agree the 4th axis sounds extremely expensive. Almost 50% of the entire machine price for a 4th axis?
One of the reasons I was looking at this one is it's locally avaliable sales and service wise.
I might look at other options, I don't want to spend $50,000 for a 3axis VMC. And I don't feel it's worth $75,000 with taxes for that setup.
Old 06-09-2008, 12:57 PM
PinnacleMachine is on a distinguished road
Where are you located? I bought my Cincinnati from them in 2000 and haven't seen or heard from them since (lack luster service).
JP
Old 06-09-2008, 01:27 PM
cam1 is on a distinguished road
Hey; That's our MM430 VMC. Bought it last year from Legere Industrial (Ottawa) for just under 50k 3X with FAGOr 8055iA control and a basic tooling package. We really like the machine, especially the FAGOR control (really easy to use). We've had no significant problems or issue with the machine. We avoided the HAAS, as with the same options the HAAS was quoted at close to 75k.
regards
Can't Fix Stupid
Alibre Users Honest Opinions xyzcnc Alibre Design 99 02-17-2010 07:37 AM
Opinions please - HF 3-in-1 shortbus_cnc General Metal Working Machines 5 01-09-2008 09:24 AM
I need your opinions triump Benchtop Machines 3 10-24-2006 05:55 AM
just need an honest opinion. SatanKlawz Mechanical Calculations/Engineering Design 20 06-01-2006 11:38 AM
A few honest questions HuFlungDung CamSoft Products 8 06-15-2004 06:24 PM
