Old 06-01-2008, 09:29 PM
kwmkoester is on a distinguished road
Clausing 4900 Headstock Bearings
I'm hoping for a little help here, I'm refurbishing a Clausing 4900 lathe and have run into a little trouble... I want to rebuild the headstock and have two gears and a spacer rust-welded onto the spindle. The gears and spacer are inside the housing and I have no way of getting a puller or seperator into position in order to safely remove the spindle. So, I think I am going to have to be kind of rough to the unit and I may damage the bearings, they are over 1000 dollars to replace through Clausing. Here are my questions... any good suggestions on loosening the 4 inches of rust-welded components from the spindle(i've tried heat, cold, WD-40 and PB Blaster) and does anyone know the specifics of the tapered roller bearings that are in this 4900? If you give me the right answer to either question you may win a prize!
Old 06-02-2008, 12:29 AM
lowpull is on a distinguished road
If you get in too much trouble I have a spare 4900 head here at the shop.
Old 06-02-2008, 04:21 PM
Really?! How much would you like for it? I realize you haven't seen mine, but, is there any rust, or more specifically, could it easily be taken apart if need be? I really appreciate your help.
Old 07-30-2008, 09:03 PM
Pancerny is on a distinguished road
4900
I'm looking for a 4900 tailstock, any chance you have one of those??
mike@customcuemaker.com
Thanks,
Mike
Old 07-30-2008, 10:55 PM
I think I have a couple. But there was only one quill. Let me look tommorrow and see what state they are in.
(something was wrong with one of them and I had it apart) but since I decided not to try and put the lathe back together, I havent gone back to it since and I dont remember what was wrong.)
This lathe was a hanger queen from the local college. They robbed some parts off of it to get the others going.
Old 11-25-2008, 09:18 PM
sodle is on a distinguished road
Any 1 3/4"X 8tpi faceplates for a Clausing? Other parts?
Howard ,
in S.ILL.
Old 11-25-2008, 09:52 PM
boaterri is on a distinguished road
I too would be interested in any face plates or chuck adapter plates you might not want. A taper attachment would be of interest too!
Thanks,
Rick
Headstock Bearings on Top Turn CNC-406 jime General Metal Working Machines 0 11-05-2007 07:54 AM
Any Info on a Clausing 6304 DublD General Metal Working Machines 2 11-01-2006 11:19 AM
Clausing 8520 CNC Retrofit? gunsmither Benchtop Machines 7 10-28-2006 01:56 PM
Clausing Lathe 13x36 Locster13 General Metal Working Machines 12 10-06-2006 02:23 PM
Clausing 8520 retrofit New2Brass General Metal Working Machines 0 03-13-2005 08:11 AM
