Old 05-30-2008, 08:16 AM
seanreit is on a distinguished road
Help me select some ground ballscrews please and other stuff
The first thing I want to accomplish is CNC of my lathe.
I have already bought two THK Linear Slides for the long axis of the Lathe, they are 18" long. Two of them.
What I need to finish the lathe is as follows:
A 400oz or greater Stepper Motor for the long axis, and a Ground Ball Screw at least 18" long with Nut assembly for mouting to the aluminum housing that will mount to the linear slides (I don't know the precise word for this part, but I will be making it).
On the short axis of the lathe (The axis that the tool is set to) I need , ball screw, nut, and a recommended stepper motor. I also need the recommended Board and parts for RPM control.
For a large CNC metal machine I am building I need recommendations for everything. I don't have a budget, but I do have the cash right now to get pretty much everything I can think of.
I have bought this for the x axis: http://cgi.ebay.com/ws/eBayISAPI.dll...m=380028807837
And this for the Y axis: http://cgi.ebay.com/ws/eBayISAPI.dll...m=380028813472
Whatever head assembly is recommended IE a treadmill motor?, the controller for that, etc. I will be using Gecko Drives I believe (I already have two spare geckodrives). I also want to get a breakout board to control RPM of the spindle. Please make a recommended list for everything. I want to get all the parts on order in the next 10 days or so.
Basically I want to build my version of the dream machine with 36" of X and 12 inches of Y with thousand ounce stepper motors. I will be buying G grade aluminum for mounting the linear slides on. At the moment, ground ball screws seams to be the hiccup in my ordering process.
Sean
Old 05-30-2008, 08:18 AM
When sizing the ballscrew, is it the same length as the linear slides? Shorter? Or longer, I'm not clear on that.
Old 05-30-2008, 08:35 AM
LeeWay's Avatar
LeeWay is on a distinguished road
I will let others comment some. I will just say that you will never get 12" travel from 11 3/4" slides.
The slides you mention are on the small side as well considering the X is normally mounted on top of the Y.
On the slides, you will loose whatever distance from outside to outside of the trucks. In other words, you automatically loose the combined truck lengths in travel plus any spacing you will have between the two.
As for screws, the same applies to the ball nut and mounting points including the ball nut mount. You simply loose this amount off the top. The design will determine the other criteria.
I would suggest if this is for a mill, that you buy at least Nema 23 495 oz. since you are using Gecko's. These have a 3/8" shaft and are very robust for the size. I run these on my mill. Consider also going with timing belts. A little more difficult than direct drive, but well worth it in the torque department.
I run these on my mill with 203V's and a 72 vdc power supply. I get power supplies and motors from Keling. Nice to do business with and quality stuff.
Lee
Old 05-30-2008, 08:44 AM
Thank you for your comments, would this be a better choice for the Y then?
http://cgi.ebay.com/ws/eBayISAPI.dll...m=150252281250
Or would you go even longer?
Old 05-30-2008, 08:50 AM
LeeWay's Avatar
I think those would be a better choice and would get you closer to you intended 12" travel.
Lee
Need Help!- To Ground or not to Ground That is the question! Mr.Chips DIY-CNC Router Table Machines 1 03-16-2008 03:10 PM
Machining/Turning the ends of ground ballscrews rodjava Linear and Rotary Motion 11 12-06-2007 10:08 AM
Mach3 tuning (cuts small stuff fine, but is off on big stuff) jdbaker Mach Software (ArtSoft software) 4 03-15-2007 11:30 AM
Motor supply ground vs Logic ground? Gashmore General Electronics Discussion 11 06-07-2005 05:21 PM
welding thick stuff to thin stuff - need advice cross6 Welding, Brazing, Soldering, Sealing 5 01-13-2005 01:39 AM
