Old 05-28-2008, 10:57 AM
phoodieman is on a distinguished road
Keyway Broach Set
I have a manual keyway broach set (Minuteman Brand). How do you set it up?
Phoodieman
Old 05-28-2008, 05:04 PM
The Minuteman broach is used with a bushing/plug sized to the bore to be broached. The bushing/plug has a groove/slot cut thru one side length-wise at the depth required to allow the broach to cut the keyway to the proper depth. Generally the broach is pushed thru with an arbor press.
If it is a larger sized keyway, the bushing/plug slot is cut deeper than finish size. After the first cut on the workpiece, a shim is inserted in the slot of the bushing/plug behind the broach. A second (or more) pass is made with the broach to achieve the final size.
Hope that helps.
Dick Z
DZASTR
SL30 want to single point broach grooves XYZ machine Haas Lathes 3 04-10-2008 02:25 PM
Keyway or not to keyway... That is the question jessbussert Stepper Motors and Drives 5 12-16-2007 07:14 AM
13mm hex broach TT350 General Metalwork Discussion 10 11-01-2007 08:15 AM
Multiple spindle or CNC? with wobble broach capabilities Speedlox Mechanical Calculations/Engineering Design 0 07-23-2006 11:05 AM
Broaching without a broach or press? Chris D General Metalwork Discussion 9 09-23-2005 02:47 AM
