Old 05-26-2008, 01:05 PM
big_hoovie is on a distinguished road
Hello / First homebuilt
Hey all,
I'm new here, and see there's a lot of info to be found from lots of very knowledgeable people, and I look forward to picking everyone's brains .
I'm considering building myself a CNC dremel machine, and have been trying to design a machine, and have a few questions, but I'll start with a little of what I would like to build, and one or two questions regarding multiple axes, and construction.
The machine I'm planning would be a 3 axis vertical milling machine, with a dremel tool as the spindle. I would like the dremel to only move on the Z-axis, and the worksurface to move on the x and y. I've considered building the ways from aluminum window channel(I've seen some pictures of machines built with this material), but I have my doubts about the strength of the material, and it's ability to resist warpage or twisting. One thought I had, was to use 3/16" or 1/4" aluminum plate and screw everything together, but I'm not sure how much more that will add to the cost - I'm going to be peicing this together over a period of time due to budget constraints.
another thought I was having, was regarding how to have the workstation move on multiple axes, and how to keep it from lifting up, and I do have an idea what I'd like to try. The picture below shows a cross-section of how I'd like to have the workstation mounted above the x-axis. the y-axis would be the same. The dark grey depicts the worksurface on top, and the support structure. The light grey is aluminum block that I'd like to mount bearings (shown in red) to. the way this is shown, I would have a set of bearings on the worksurface as well as on the way(?), thus keeping anything from lifting during machining, and allowing smooth movement. My question regarding this is - Is this a feasable idea, and what sort of clearances will I need to keep, to be able to assemble this(I plan to put everything together, then slide the sections together, so presumably it can't be too tight). Any ideas or suggestions?
Homebuilt cnc router for lithophanes? Timandjulianne Vectric 6 04-06-2008 06:11 PM
My homebuilt cnc router is finished! JMValios DIY-CNC Router Table Machines 13 04-25-2006 04:17 PM
My completed homebuilt cnc router cncmage DIY-CNC Router Table Machines 7 04-12-2006 12:42 PM
Homebuilt machine accuracy atomgonuclear CNCzone Club House 15 02-13-2006 08:57 AM
homebuilt cnc mill MBG General Metal Working Machines 8 10-21-2005 10:49 PM
