Old 05-19-2008, 11:29 PM
Jerryk480 is on a distinguished road
Need help with Leblond Makino MC40
I have purchased a used Leblond Makino MC40 (1984) and I can not unlock memory protect. I have only some of the manuals for the system and from what I have read is that you press memory protect and the display should display 13577270, you then enter the same # and hit set. What happens when I hit memory protect is the display reeds,
blank blank blank 4. blank 0 blank blank
When I try to inter this I can not enter blank or (.) . Maybe the code has been changed; if so is there a way to set it back to the old code? I am new to CNC machining so I apologize if this is a stupid question can any one please help with this?
Thanks Jerry.
Old 06-26-2008, 09:02 PM
Smile Found suluthion!
I finnaly found that if i unplug the battery on the cpu the system defaults to the standerd code.
Old 09-26-2008, 01:00 AM
AppEng is on a distinguished road
Call Makino...I believe thier number is 1-800-MAKINO-4 for service. It should be a very simple fix over the phone, and shouldn't cost you a dime.
Leblond Makino FNC60 ???? SGARCIAM CNC Machining Centers 0 03-13-2008 09:25 PM
LeBlond Makino jhhdez CNC Tooling 2 01-17-2008 03:34 PM
Leblond Makino (fanuc OM) Problem Masood Fanuc 6 09-22-2006 01:55 AM
