Old 05-16-2008, 04:00 PM
frankg521's Avatar
frankg521 is an unknown quantity at this point
Bearing Heater
Just thought i would share this tip I am rebuilding a vaccumm pump and it needed new bearings i didn't have a press handy so i put the shaft in the freezer and the bearing on a good heater.... A coffee pot warmer
ID:	59685   Click image for larger version
Old 05-17-2008, 10:46 AM
frankg521, Good idea!! Can you keep the heat low enough to avoid melting seals or cooking grease out of sealed bearings? If so, you just converted my unused coffee pot warmer to a bearing heater.
Dick Z
DZASTR
Old 05-19-2008, 06:01 PM
frankg521's Avatar
i just turned on the switch put the bearing on for 10 minutes it worked great
Old 05-20-2008, 09:59 AM
PMT PMT is offline
PMT is on a distinguished road
If you are doing a spindle where you have open bearings I would recommend against putting the spindle in the freezer. The coffee pot thing is good but if you cool the spindle as well you will get a ton of condensation all over your new bearings as the spindle warms up. Typically just heating up the bearing should expand enough to get on to the shaft easily.
Fanuc a50c heater problem sting_dot Fanuc 0 06-05-2007 12:16 AM
Waste oil heater murphy625 CNCzone Club House 4 02-12-2007 07:47 AM
Calcium Carbide Heater krt9751 CNCzone Club House 1 07-10-2006 01:49 AM
R2E3 Overload Heater dfmiller Bridgeport and Hardinge Mills 2 07-20-2005 04:08 PM
Induction heater - plans oskars Welding, Brazing, Soldering, Sealing 2 01-23-2005 12:34 PM
