Old 05-14-2008, 02:21 PM
rayminette is on a distinguished road
Help with EZ Path SD Utilities
Hello,
I'm not a machinist but I am a network engineer and I have become responsible for a network and about 5 EZ Path lathes that need to be backed up. For 4 of the lathes, they are standard EZ Path lathes and I push 9 to go out to the Utilities menu and then 2 to back up the pgms etc to a floppy. 1 lathe is an EZ Path SD and totally different from the others, when I push 9 for utilities on that one, it just lists all the files and no menu.
I need to know how to run a backup of the SD, so it is in a zip file on a floppy like the other lathes.
Can anyone help or point me in the direction where I could find some help?
Thanks so much
Ray
Old 05-21-2008, 03:10 PM
Bump
Anyone?
Utilities Menu? donl517 Fadal 3 07-17-2007 12:32 PM
g-code with master cnc utilities SHEDCNC G-Code Programing 6 04-03-2007 06:15 PM
EZ Utilities Software EvoEndZ General CNC (Mill and Lathe) Control Software (NC) 0 03-26-2007 07:06 PM
Change - from linear path control to CNC path control fidibus42 General Electronics Discussion 1 12-04-2005 11:43 AM
