Old 05-12-2008, 10:43 AM
F500 is on a distinguished road
Cutting a keyway groove on a drill press?
I have two 6061 alum. hubs that have 1/4" keyway grooves in them. I need to widen the groove to 5/16". Is there anyway easy way to do this using a drill press? Other suggestions for a DIY solution?
Old 05-12-2008, 11:33 AM
jalessi's Avatar
jalessi is on a distinguished road
This will work!
Hope this gives you some direction.
http://www.keyseaters.com/stock_custom_keyseating.htm
Old 05-12-2008, 12:18 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
It is HIGHLY NOT RECOMMENDED, but you could use a single or 2 axis machine table to attempt it.
http://www.kbctools.com/can/Navigati...fm?PDFPage=453
www.integratedmechanical.ca
Old 05-12-2008, 05:58 PM
Minuteman broach kit? Opening a 1/4" keyway to 5/16" in aluminum shouldn't be too difficult.
Dick Z
DZASTR
Old 05-12-2008, 06:18 PM
Thanks everyone.
OK, so I learned about broaches and actually found a 5/16C broach and 1 3/8 bushing for about $50. Now it seems I need a $$$ machine to use it? What type of manual machine is available to push the broach? Sorry for the newbie-type question.
Old 05-12-2008, 06:36 PM
snowshovelbmx is on a distinguished road
try an arbor press. shouldn't be too hard to track one down to use.
"you don't even need cnc if your handy with a torch"
Old 05-13-2008, 08:29 AM
Kiwi is on a distinguished road
Originally Posted by F500 View Post
.....Is there anyway easy way to do this using a drill press? Other suggestions for a DIY solution?
A 1/2inch drill press may be on the light side but a Mill/Drill will do the job.
Make an arbor and broach with the spindle locked.
Old 05-13-2008, 12:22 PM
pixburghenat is on a distinguished road
Aluminum??
How about a hand file and a bench vise.
pix
Some of my best finds were in the trash....
Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press. Geof General Metalwork Discussion 47 02-01-2008 02:32 PM
Keyway cutting in SL30 Five-10 Haas Mills 5 03-01-2007 08:10 AM
cutting keyway on long shaft territorialmill General Metalwork Discussion 13 12-04-2006 10:35 AM
Keyway cutting itsme General Metalwork Discussion 10 05-31-2005 08:27 AM
Drill Press or Mill/Drill? cbcnc Benchtop Machines 2 03-05-2005 06:03 PM
