Old 08-26-2004, 09:29 PM
replicapro is on a distinguished road
Make a rotary table into a 4 jaw chuck
I saw that most people do this
Would it be possible to drill and tap a hole in the t-slot of a rotary table and insert the jaws for the chuck?
Im running out of room and adding another 4 inches in height to add a chuck or vise seems to much.
Old 08-26-2004, 09:33 PM
IJ. IJ. is offline
Gold Member
IJ. is on a distinguished road
I've seen those little Vices that are just a fancy clamp system that might work bolted to the T slot with minimal height!
(I think from memory JFettig made one from plans he found on the web)
Old 08-26-2004, 11:15 PM
Konrad's Avatar
Konrad is on a distinguished road
You could look into in taking that rotary table right off [whats turning] and mount your 4 Jaw chuck directly, might have to get a slightly larger one to have the same O.D.
Konrad
Old 08-28-2004, 09:56 PM
inthedark's Avatar
inthedark is on a distinguished road
I took a used Westcott 4-jaw, and made a steel plate so it would bolt easily to my rotary table (7" Yuasa). The plate had opposing extruded centers that fit snugly into the rotary table and the chuck (no brainer centering), the holes were counterbored 3/16 socket head cap screws so it was easy to bolt on to the T-slots on the table as well. Then the chuck bolted right on.
Adapter plates are expensive, it was a worthwile project. It has been very handy to use both in horizontal and vertical positions.
Thanks,
"Plan your work; Work your plan"
What 3 jaw chuck for a 165 rotary table? nervis1 Fadal 15 11-14-2008 03:29 PM
Build a CNC rotary table? (longish) jcolley Mechanical Calculations/Engineering Design 0 02-12-2005 08:23 AM
rotary table chuck senor J. General Metalwork Discussion 2 12-15-2004 03:21 AM
chuck for rotary table replicapro General Metalwork Discussion 2 11-08-2004 08:47 AM
Cross slide work pc on rotary table replicapro General Metalwork Discussion 4 07-08-2004 05:30 AM
