Old 05-05-2008, 05:24 AM
ferrumdg is on a distinguished road
Question Repeated cutting of 6AL4V Titanium - making small series - questions...?
Hello,
this is my first post here... my name's Daniel, and I work as a bladesmith & machinist in switzerland, running my own small shop.
(http://www.ferrumdg.com for those who want to know more.)
When I make folding knives, one part of the job is to cut a 1,5mm (0.059") Ti-sheet (6AL4V - grade 5)... basically I need two identical pieces each time, one with some additional mods, but the outline is exactly the same.
Now I'm working on a small series of ten identical folders, so I would need twenty Ti-liners cut out, identical to each other.
I could send this off to a local laser or even better a water-jet cutting shop, and get it done that way.
However for a long time now I was wondering if there's any "small-shop" way of doing this, with some speed and precision?
I haven't sean any DIY WaterJet cutting tools or stuff like that.
I've seen some DIY Wire EDM Setups, but have no idea what the capacity and precision of these are...
Any ideas? machine plans? solutions.
if I do single pieces, I use a band saw to cut the rough shape out, and then grind and mill it after having made a plastic prototype I use to transfer the outlines. it's simple and it works, but it's time consuming as well.
Thanks,
Daniel
Old 11-23-2008, 08:39 AM
rab's Avatar
rab rab is offline
rab is on a distinguished road
How about a small cnc milling machine ?
I use mine for cutting titanium blades, etc.
Just been looking at your website - very nice work you're doing there.
Rab
CNC Toolkit
Tapping very small holes on titanium DIYist General Metalwork Discussion 9 03-17-2009 02:34 PM
cutting a taper on titanium rod marty7001 General Metalwork Discussion 4 07-20-2007 04:17 PM
Making PCB's with a small cnc mill DennisCNC CNCzone Club House 4 12-21-2006 05:51 AM
Turning Small Titanium parts ?? BFcarbon Employment Opportunity 0 05-11-2006 08:16 AM
Titanium cutting? What to use! Tazzer General Metal Working Machines 6 11-20-2003 07:56 PM
