Old 05-02-2008, 01:30 PM
brgrii is on a distinguished road
Tool wobble
I have a 25 yr old knee mill with tapered tool holders that is (suddenly, or was it always this way? I know not) exibiting about 5 thou per inch of tool wobble. I checked the spindle and it is within a thou - ok for an old machine I thought - I think I can live with that.
Why is the tool off more that that the further I am from the spindle, how do I fix it (or get it fixed), and just in case I want a even more accurate machine, how would I get the spindle run out down as well?
Thanks!
Old 05-02-2008, 04:16 PM
fuzzyracing1967 is on a distinguished road
(Why is the tool off more that that the further I am from the spindle)
The farther from the spindle you go the more run out you will have,your tool is at a slight angle from the spindle.Think of a dart board,at the center the lines are close but the farther you go out the farther apart the lines are.You may have a small bumpor a chip on the tool holder or in the spindle itself,just take some emery paper and clean them up,this allso goes for the tool holder itself.
Changing tool diameter in the tool offset screen Vern Smith Haas Mills 21 09-24-2008 10:54 AM
Very slow tool change on Tool Room Mill Capt Crunch Haas Mills 3 12-21-2007 01:20 PM
G43.1 - Tool Axis Direction Tool Length Compensatioin EngTech Mazak, Mitsubishi, Mazatrol 8 12-06-2007 05:01 AM
Multiple spindle or CNC? with wobble broach capabilities Speedlox Mechanical Calculations/Engineering Design 0 07-23-2006 12:05 PM
