Old 04-30-2008, 01:43 PM
samu's Avatar
samu is on a distinguished road
leveling???
My machine table has a banana shape on X axis (about .08mm on 1000mm) and a constant slope on Y axis(about .05mm on 500mm). Could it be a leveling issue?? It is a hardinge VMC1000.
Old 05-01-2008, 03:55 PM
skrueger is on a distinguished road
Is your turkite still good? What do the ways look like? You may have to install hold down bolts & "pull" it back into spec.
Old 05-01-2008, 04:02 PM
samu's Avatar
it is on linear bearing and they look good
Old 05-11-2008, 08:51 PM
micfixer is on a distinguished road
In any machine installation,The 1st thing that is done is leveling the machine.Eliminate that error to start with. If you are shaped like a bannana you may not be supported enough in the middle of the machine. Use a precision level .0005 per foot increments.When machines are built, they are built level and aligned from there.
check it out and good luck
Just got an '02 VF2...quick leveling ? JMFabrications Haas Mills 3 07-09-2007 12:06 PM
Leveling, Isolation of Bridgeport mxtras Bridgeport and Hardinge Mills 14 08-11-2006 03:38 PM
swivel leveling feet DanOSB Mechanical Calculations/Engineering Design 4 09-20-2005 09:37 AM
Leveling a CNC Machine samualt DIY-CNC Router Table Machines 1 06-06-2004 05:59 PM
Left to right leveling. ynneb DIY-CNC Router Table Machines 4 03-15-2004 09:00 AM
