  #13   Ban this user!
Old 05-12-2008, 12:00 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Okay, for clarification:
The G1005Z HAS to have a fine feed, because there is no other way to move the tool up and down but the quill levers. So you are limited to the 3 inches or so of Z movement. I would bet that the fine feed is graduated in increments of .001 inch.
The G0463 has no fine feed on the quill, but it DOES have a handwheel to raise and lower the entire head. This handwheel is graduated in increments of .001 inch. So you would MILL with the .001 Z handwheel and DRILL with the quill levers.
The G0619 HAS a fine feed for the quill, which has NO graduations or scale at all. It relies on the DRO. But it ALSO has a hand wheel to move the entire head up and down. THIS handwheel is graduated in increments of .0005 inch.
CR.
Round column mill rodzilla Benchtop Machines 4 08-15-2007 08:00 PM
dovetail mill column vs spindle servo cncJerry Benchtop Machines 1 03-17-2007 03:51 PM
Opinions on the Enco dovetail column mill? KTP General Metal Working Machines 1 07-27-2006 10:10 PM
Round column mill SCROMAL General Metalwork Discussion 1 06-18-2006 12:23 PM
HARBOR FREIGHT small round column mill to a square column conversion. motomitch1 Vertical Mill, Lathe Project Log 25 12-01-2005 10:24 AM
