Old 08-23-2004, 03:28 AM
*Registered*
CNCPlastic is on a distinguished road
CNC Lathemaster/Industrial Hobbies Mill - First Part
Wow this cnc stuff was no small undertaking, finished converting the mill (Industrial Hobbies kit) a few weeks back then added flood coolant (as you can see coolant containment is a work in progress ) then set about learning Onecnc, finished my first program this weekend, then got the computers talking on a wireless network and (drum roll) finally the mill is making parts. Less there be any doubt why IH coolant proofs everything just look at the coolant flooding all over the cnc parts.
Here's a closeup, I can't really call those chips they are more like plastic curly fries. Hmmm looks like I still have some brown goop to clean off the spindal.
Here's half the part, I had to split this into 2 programs as the OD is 13 inches and I only have 9 inches of travel on Y. All total there are 640 3/16" holes drilled. This put Onecnc's fancy new hole feature recognition to the test and it performed wonderfully, all I did was click the mouse a few times and poof a few thousand lines of deep hole peck drilling code was born.
The part if anyone is interested is an experiment board for winding concentric coplaner metal detector coils, supports coils 7 to 13 inches OD.
Old 08-23-2004, 12:35 PM
IndHobby is on a distinguished road
Is that cutting board I see on the table
That Idea looks familiar.
Aaron Moss
www.IndustrialHobbies.com
Old 08-23-2004, 02:20 PM
Gold Member
Ken_Shea is on a distinguished road
Looking very good, and now all that work is turned into reality, congratulations. Actually 9" Y travel is really good for a little machine.
Old 08-23-2004, 03:00 PM
*Registered*
Yeah you caught me pilfering yet another idea from your web site. Those cutting boards are so cheap compared with buying 1/2 inch plastic plate that I purchased several, that's a second one I'm drilling full of holes on the mill.
It cuts very nice, I drilled it 15ipm at 1,100 rpm and I think I could have sped that up quite a bit. Cobalt bit.
Aaron Moss
Old 08-23-2004, 03:02 PM
*Registered*
Thanks, yeah it only comes with barely 7 inches of Y travel, I bumped it out 3 inches. I have 9 7/8 on Y but left some room for uh...error. lol
Old 08-23-2004, 03:53 PM
*Registered*
Here's the finished part, circle is 13 inches OD, roughly 640 holes 3/16 x .400 deep.
Old 08-23-2004, 05:30 PM
IJ. IJ. is offline
Gold Member
IJ. is on a distinguished road
CNCPlastic: Brilliant!
How did you relocate it when you turned the workpiece for the 2nd pass?
Old 08-23-2004, 05:35 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
very nice
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 08-23-2004, 06:03 PM
*Registered*
ESjaavik is on a distinguished road
He wrote it's for winding metal detector coils. May I guess that pegs are put in the holes in an omega pattern and the wire is wound over the pegs?
Old 08-23-2004, 06:41 PM
Gold Member
JFettig is on a distinguished road
thats pretty cool man. what are you using for coolant? it looks like strait water.... maybe some antifreeze? thats probably not good on the machine, get some real stuff, you wont regret it, kinda sucks that most places only sell it in 5 gallon pails or bigger, luckily I could get mine from work.
Jon
Old 08-23-2004, 10:07 PM
*Registered*
Dumb luck really, I turned it around, zero'd X and Y again and it was right on.
What I should have done is clamped the part down, zero'd X and Y, then use the mill to cut two alignment holes equal lengths apart on the part center line. That would have assured that when turned the part around everything would be perfectly positioned.
Old 08-23-2004, 10:11 PM
*Registered*
Yes on the pegs, these coils are simply round however I know the omega style you mentioned. Transmit coil outer, receive coil inner, bucking coil around receive coil. In this case the receive coils are half the size of the transmit thats why the inner circles are so close together. Next up another jig for winding induction balanced double D coils.
Using your CNC Mill as a CNC Lathe lstool Knee Vertical Mills 10 08-02-2010 01:06 AM
Pictures of My Lathe & CNC MILL studysession General Metal Working Machines 14 01-04-2005 05:07 PM
Which CNC Mill and what software? MaxxMan-X Knee Vertical Mills 16 04-18-2004 12:25 PM
Need to CNC my mill quickly - advise? SRT Mike General Metal Working Machines 3 03-15-2004 01:10 PM
