Well, if you use 3:1, then max rpm will be 900. So on a 5TPI screw, that will give a max speed of 180 IPM! Are you needing more speed![]()
I going to convert my X3 to CNC. I'm considering using some of the "Cheap"
clifton servo motors at 360/oz-in PEAK. Will these motors have enough power in a 2:1 ratio or should I go to 3:1? Peak RPM is about 2700
Thanks!
Bob
No, I don't need more speed, but what about torque? I guess my real question is, what would be the best ratio so that torque is enough without killing the motors and also have decent speed?
Thanks!
Bob
I don't realy know the size of the mill, but I reckon 3:1 would be fine with a peak torque of over 1000 oz/in. Hopefully someone with more knowledge of that mill will chime in soon.
The Mill Size is bigger then a mini mill, may be a little smaller then a mill/drillOriginally Posted by kong
about 300 lbs. if that helps!
Bob
Well, if it were me, I would go 3:1, it it certainly fast enough, and probably more torque than your spindle can cope with anyhowYou could even go 4:1, but then you get the problem of the pulleys being too big! Yep, 3:1 is good.
