Old 04-16-2008, 02:52 AM
rtwas is on a distinguished road
iso-30 spindle conversion for the Seig X3
Hello,
I keep running into cnczone.com posts on the web about iso-30 and bt-30 type spindles
for various benchtop mills. The problem is these posts are old and I can find little or
nothing about (spindle kit vendors etc) it on the web.
There was some mention of a spindle conversion being sold by *industrialhobbies.com*
but apparently that was two years ago or more and there does'nt seem to be anything on their site about it now.
Is there any current info on replacement spindles (automated tool change type) for the Seig X3 for #30 taper tool holders?
Thanks.
Robert W.
Old 04-18-2008, 10:39 PM
skullworks is on a distinguished road
Exclamation NMTB 30 spindles
Industrial Hobbies (back when Aaron owned the outfit) had looked into, and had a small lot of NMTB 30 spindles made up specifically for the IH mill.
IH (Now) offeres the NMTB 30 as an upgrade option ( for the IH mill, and no you can't make it fit an X3).
NMTB 30 requires a draw bar.
BT 30 uses pull stud type retention.
Doing a NMTB 30 for the X3 is something I have been exploring, most likely you would lose all quill movement as the spindle would be mounted in the head.
I doubt you will see much in the way of an automatic toolchanger, there just isn't much room there.
The Tormach system is likely your best bet for quick change tooling.
Seig X3 Conversion with Deluxe CNCFusion Kit MRM RCModels Benchtop Machines 298 05-03-2011 07:58 AM
Seig X1 mill - Initial Conversion Design - pdfs jeffo2001 Benchtop Machines 4 02-20-2009 08:47 AM
spindle speed control borked on SEIG x2 imf Benchtop Machines 7 06-29-2006 07:52 AM
Spindle speed for Sieg conversion rcotteleer Mach Software (ArtSoft software) 4 01-09-2006 01:29 AM
New spindle motor conversion JFettig Benchtop Machines 22 12-18-2004 09:53 AM
