Old 04-15-2008, 05:36 PM
the_0utsid is on a distinguished road
Precision???
I recently bought a mill/drill (http://www.harborfreight.com/cpi/cta...emnumber=44991)
and cutters.
The first few things i noticed:
-using the drill chuck with a drill bit and the tip of the drill bit wobbles.
Q: Any comon fix to fix this? I used a tool holder holding a cutter and turning by hand, it appears the machine shaft does not wobble.
-using a .625" cutter on hot rolled steel and everything vibrates - the cutter goes side to side, x axis wobbles front to back, etc. I noticed the "lead screw"?? kindof stays stable but the bearing on the end has play so the table wobbles. I tightened up the set screws and it only helped some. i also used a 1/4" cutter and plunging, the machine still wobbled.
Q: anyone use this machine and yours does not do this? Did i need to get a Bridgeport to even think of cutting steel accurately?
anyone build your own endplates adding thrust bearings to reduce the play as in my situation?
Old 04-15-2008, 08:24 PM
cam1 is on a distinguished road
Hi: Caveat Emptor is the best advice I can give.
regards
Can't Fix Stupid
Old 04-16-2008, 06:26 AM
The Blight's Avatar
The Blight is on a distinguished road
THe mill you have bought is an X2, and you should post in the benchtop section. How deep are you cutting? Have you checked the ways for slop? If you havnt you should lap the ways, and tighten down the gibs. The Y axis on this mill does not have any bearings, so you might want to make some. Lock down all the axis that are not in use when cutting.
I have not tried my mill on steel yet, but I might try it just to see how good it is.
Old 04-16-2008, 06:37 AM
blackbeard52 is on a distinguished road
See what Hoss is doing with this machine....pretty impressive with a bit of tweeking...
http://www.hossmachine.info/
Bob
SMW Precision DRO for X2? awetmore Benchtop Machines 2 02-23-2008 08:52 AM
H-T Precision toan Product Announcements & Manufacturer News 2 09-03-2007 10:02 PM
How much precision is enough ? scyan Syil Products 13 04-10-2007 12:29 PM
precision servos (digital) vs. precision stepper (<3.6degree step angle) bennyben Servo Motors and Drives 6 03-05-2004 11:11 PM
