Old 04-10-2008, 06:07 AM
praest is on a distinguished road
Angry Drilling in W.EN 1.4980 /AISI 660
I need to make some ø13mm holes right through (l=72mm).material is 1.4980/660. It's a bleeding hell drilling this stuff.
I prefere a supplier in europe/denmark
any help is appreciatet
CEAndersen.dk :specialty production in stainless steel
Old 04-10-2008, 07:31 AM
MarshallfromCT is on a distinguished road
What type of machine and stock are you using we need more infor what RPM is the machine max. and what type of drill
Old 04-10-2008, 07:45 AM
In fact I'm asking for a former woorkmate.
I know the matrial and ther's 400 of them.It's to be done at a (older) Mazak bench.
Can't remember max rpm, about 4000
>>just got confermation 4000 rpm max<<
I need to know which type off drill that would be best buy
Old 04-10-2008, 08:09 AM
try this like for free soft wear for your feeds and speeds and the size of the drill this should help get you close start slow and try faster and you have luck I have drilled in all types of SS and you should not have any problem but the right drill will make life easer
http://www.freedownloadscenter.com/B...onsultant.html
1mm or 0-80 drilling in al star1280 General Metalwork Discussion 10 12-18-2007 11:07 PM
drilling and drilling cycles tutorial wmorre General Metalwork Discussion 0 10-18-2006 07:30 PM
Can I drill AISI 1020 plate steel with a drill bit? Apples General Metalwork Discussion 2 02-01-2006 12:15 PM
PCB Drilling drk Carken Products (Deskam, DeskCNC etc) 3 12-14-2004 09:27 AM
Drilling .09 thk SS Machine1 Hard and High Speed Machining 17 12-12-2003 12:46 PM
