Old 04-09-2008, 10:33 PM
jacek is on a distinguished road
Question Unknown surface grinder in need of tlc
hey everyone,
as i am usually good at reverse engineering any machinery, a friend of mine came to ask my help on repairing the feed speed rate on his surface grinder. Never having played in one before i tried to find more information on the machine, but all parts and tags have been sanded down to have a nice water-soluble paint applied.. like this will last long!
More detail. the x feed rate is adjusted by a small lever arm on the apron, and rotating it around will bring 2 sweet spot where it crawls around. He tried to adjust the speed of his hydraulic pump in the base, and got a marginaly better speed increase, but this came from 100psi and bumping it up to 140psi! Not good. Now i have to figure out the guts and innards of the new beast sitting in front of me.
Can anyone point me either in the direction of a few schematics or better yet figure out the type of machine it is?
thanks everyone!
ID:	57292   Click image for larger version
ID:	57293   Click image for larger version
Old 04-11-2008, 03:14 PM
VWSatOz is on a distinguished road
Ive seen the insignia on the front panel somewhere before... might be Sven Jakobsen from Denmark, could be Kirloskar from India, or might be a Russian
I would strip down the hydraulic valves & give a good cleanout, clean out the hydraulic tank of all grinding grit etc, new hydraulic oil etc. If a spool is dirty & sticking it wont shift properly. On some machines the grinding dust will drop down the back of the table & somehow get into the tank IF the tank sits INside the mc base
Old 04-11-2008, 05:51 PM
this is what i guess i will have to do. Although i prefer to have a manual this time i will be going in blind. Good thing i can reverse engineer anything somewhat easily.
The oil tank is inside the base; i had assume they would have made the tank and valve seamless. With your pointer i can see where the problem might be, i will take it apart this weekend and see what i can make of it.
thank-you!
would anyone happen to have a schematic of a similar surface grinder?
Old 04-12-2008, 01:38 AM
juergenwt is on a distinguished road
Try and google" ELB-Schliff Werkzeugmaschinen", Germany. The Logo looks the same. Juergenwt
Tags
grinder, repair, surface, unknown
How does a surface grinder work. SmoggyTurnip General Metal Working Machines 6 02-17-2008 05:57 PM
Surface grinder improvement caliper General Metalwork Discussion 10 12-02-2007 01:40 PM
Please help! Surface grinder questions. tntmachine General Metal Working Machines 5 11-16-2007 01:54 PM
Surface Grinder gbowne1 General Metal Working Machines 12 02-28-2007 12:28 AM
Surface Grinder itsme General Metal Working Machines 18 09-13-2006 01:28 AM
