Old 04-07-2008, 07:43 PM
jsansoterra is on a distinguished road
R8 tooling question
I have an SX3 mill and recently ordered a Deluxe R8 12-piece collet set from Grizzly http://www.grizzly.com/products/12-p...llet-Set/G1646
None of the collets fit the spindle of the SX3. They appear to be R8 but the keyway slot is smaller. Each collet was individually packaged and labeled as R8.
Other R8 tools work okay (R8 boring head, R8 end-mill holder, etc.).
Am I missing something or is it just cheap collets?
Should I return these to Grizzly or is this a common occurence and I should just mill out the keyway?
Thanks!
Old 04-07-2008, 08:09 PM
cam1 is on a distinguished road
Try this: There is a setscrew in the spindle to engage on the keyway. If you are lucky it is accesible without requiring spindle removal. Back it off until the collet slides in freely, then use some removable loctite to set.
The keyway is just there to prevent the collet from spinning during the tightening process.Sometimes the offshore R8 collets do not have a deep eneough keyway.
regards
Old 04-08-2008, 02:07 AM
Thank you. I will try this.
Old 04-10-2008, 06:43 PM
richard k is on a distinguished road
Often the offore R8 stuff requires a few strokes with the edge of a mill file in the keyway. Generally I find it is just a few burrs or rough finish.
Sure is annoying
Richard K
What is Live tooling versus "non-live tooling"? squale General Metal Working Machines 8 11-15-2007 02:38 PM
Tooling question mike102668 General Metal Working Machines 7 08-09-2007 08:17 PM
TL1 Tooling Acc. Question elaganis Haas Mills 9 06-15-2007 09:24 AM
TW-10 live tooling question davisboys General Metal Working Machines 0 01-11-2007 06:48 PM
Mill Tooling Question kochevnik General Metalwork Discussion 7 01-11-2007 11:40 AM
