Old 04-04-2008, 11:35 PM
yngndrw is on a distinguished road
CNC Mill Design
Hi all,
I'm interested in designing a long-term project - Building a CNC milling machine.
I don't have any hands-on experiance with milling nor with CNC, however I do know my mechanics, electronics and programming and am able to work out numbers / positions in my head easily. I'm also a 19year old University student so I'm also limited on cash. This means that my previous statement of this being a long-term project was no lie. :P
Anyway, what I'm thinking of is a 3 axis fixed bed milling machine with a detachable head. This means that the milling head could be removed and swapped for a laser, at some point in the future.
The mill would be mainly used for milling aluminium and copper.
I didn't want a moving bed because I don't want to have to clamp stuff down when it's in "laser mode". (Thinking ahead, mroe than anything.) I understand that there are risks with moving laser tubes about, however I think that if it's moved carefully enough (Not at max speed.) it would be fine.
The bed would have T Slots in it so that the work piece can be clamped when milling and then a sacrificial wooden (MDF ?) top would be placed over it when laser cutting, so that the main bed isn't damaged.
The unit would have a bed of aprox size 20" x 30" and maybe Z movement of 10-15" to allow the use of an automatic toolchanger.
Each of the axes would be driven by ballscrews.
I was going to use these anti-backlash leadnuts:
http://www.dumpstercnc.com/leadnuts.html
The basic design that I was thinking of is line one posted by Oneeye: (I think his username was.)
http://www.cnczone.com/forums/attach...1&d=1207369799
I think that this design is very neat and would suit my requirements.
I also verymuch like the design of this spindle and toolchanger: (At the very bottom.)
http://www.cncathome.com/spindles.html
I was thinking of getting one of those motors and making a copy of it.
No real thought into the laser stuff yet - I don't have the money for it and won't do for some time.
For the controllers, I was going to design and make them all myself.
So, why am I posting ? Well I wanted to know what you guys (And girls.) thought of my project. Are there any wise words or bits of advice, so that I don't have to learn the hard way ? If you were me, what would you change ?
Thanks,
-Andrew.
Edit: Question regarding vacuum tables with laser cutters. How do you stop the laser from wrecking the vacuum table ?
CNC Mill Design MattP Open Source CNC Machine Designs 2 09-30-2008 11:18 AM
DIY CNC Precision Mill Design&Build RogerRetro General Metal Working Machines 12 03-19-2008 02:09 AM
Unorthodox CNC Mill Design Zach_G General Metal Working Machines 16 05-26-2007 12:06 AM
help with CNC Mill (design) bigtonyicu General Metal Working Machines 8 10-18-2006 10:32 AM
CNC Mill Electronics Design apollo General Electronics Discussion 0 04-14-2004 07:57 AM
