Old 08-12-2004, 07:47 PM
replicapro is on a distinguished road
SIEG X3 OWNERS chime in
Just wondering who here has an X3.
Old 08-13-2004, 12:33 PM
Bird_E is on a distinguished road
Yes, I have one and I love it... .I want to convert it to CNC but still looking for someone who has already done it so I can get some tips and directions!
THanks!
What size steppers/ servos ball screw info etc...
Bob
Old 08-13-2004, 12:44 PM
Im in the middle of converting mine to CNC I got my servos and stuff from Camtronics and im in the middle of making ball screw assemby.
Old 08-13-2004, 12:48 PM
Very nice, what size servos are you planning on using? How do you plan to do the "Z" axis?
Are you going to use preloaded nuts?
I have lots of questions! :-)
Thanks!
Bob
Old 08-13-2004, 06:26 PM
Gold Member
marvinstov is on a distinguished road
I've had an X3 for a couple months now. Great machine. Doing business with Bob at Lathemaster is a pleasure too. No problems at all with it. Not planning on a CNC conversion any time soon but I do have a lot of the parts if I decide to. Anyone thinking about a larger mill than a Mini but smaller than a Bridgport should take a look at an X3.
Marv
Old 08-13-2004, 06:40 PM
I got the clifton 420 oz servos with 250 encoders. Im doing 4 axis on a 6 inch rotary table. The z axis will also be replaced with ball screws, Im going to remove the electronics control box and mount it on the wall then mount a servo behind the mill near the top of the z axis. This way I can run a belt right to the ball screw and not have to run through the rack and peanut gear. I will most likely take that gear off but im going to wait and see if it needs to be messed with.
As for the ball nuts, im doing the preload by using 2 nuts locked together as some of the other guys have done.
So far I have manually milled the x axis servo and ball screw set up. Im going to mill the rest of the axis's before I start swapping them out. My goal is to not modify the mill it self at all, fabricating all now mounting blocks and plates for the ballscrews. That way if I mess up I can put the lead screws back on with no problems. As you can see in the photo above in my last post the plate is the same shape as the exsisting plate only thicker and taller to accept the servo mount. I have not installed the press bearings yet, but there are thrust bearings in the plate.
Old 08-13-2004, 07:13 PM
Gold Member
Replicapro,
What are you calling the "rack and peanut gear"?
Marv
Old 08-13-2004, 07:15 PM
Thats What Homer Simpson calls Rack and pinion. Just a joke
Old 08-13-2004, 11:54 PM
Gold Member
Ok, I don't watch Homer.
Old 08-15-2004, 10:17 PM
JOE65's Avatar
JOE65 is on a distinguished road
Is this an x3?
  #11   Ban this user!
Old 08-15-2004, 10:32 PM
DSL PWR is on a distinguished road
The casting looks different. It's some other knock off.
Old 08-15-2004, 10:56 PM
Gold Member
No, that's bigger than an X3. Looks like a nice one though.
New Plans to convert a Sieg Mini-Mill to CNC rsteele Product Announcements & Manufacturer News 2 09-19-2011 02:18 PM
Sieg Lathe Accessories studysession General Metal Working Machines 4 09-22-2008 04:43 AM
Sieg X3 Mill CNCadmin General Metal Working Machines 7 02-09-2005 09:23 AM
Ordered a Sieg X3 today CNCadmin General Metal Working Machines 6 02-04-2005 09:53 AM
Sieg X3 motomitch1 Benchtop Machines 3 09-21-2004 09:03 PM
