Old 04-01-2008, 11:50 PM
Brenck is on a distinguished road
Cool Confused To Choose CNC Geometry
Hi everyone, im about to build another CNC machine, but now i want to make something really tuff!!! Im thinking on use 1'' thick ( or more ) plates of 7075 Alum. On every single part of the structure.
I want to use it to machine Iron, Aluminium, Steel and maybe Stainless Steel...
Im confused about what kinda geometry to use, like, fixed table with all moving structure ( Like thoose really big wood routers that machine a entire MDF sheet at once, the ones that the table doesnt move at all and its the spindle that goes x,y and z )
Or fixed Y axis, so the Y axis carry the Z and the X axis moves just the table foward and backwards.
Or fixed Z axis, so the Z its attached to a collumn and below you have a x,y table...
I wanted to do it fixed table. Im already used to build like that...
But in terms of structure, precision and tuffness i dont know if its the best choice....
I want to know even if i build really solid and well structured machien with the fixed table, would it still be better to build with moving z and moving x table or x,y table and fixed z? Because I have never seen a metal working machine with fixed table...
Thanks for the attention everyone
Old 04-02-2008, 12:16 AM
Gizmot is on a distinguished road
check there:
http://www.f-zimmermann.com/
Old 09-25-2009, 09:31 PM
*Registered*
conceptmachiner is on a distinguished road
Spindle??
You want to build heavy machine to cut steel SS/
what type of spindle do you want to use?
i found interesting type here http://www.milwaukeemachinetool.com/...d_spindles.htm
New one start from $ 5200.00
I think i be interesting in something similar but used one.
It uses CAT 30 taper and tool can be 1.25 "
Tags
help metal machine table
geometry Htech Fanuc 1 12-09-2007 11:25 AM
Geometry from solids GigaHz Surfcam 4 04-17-2007 04:58 PM
Geometry from NC rherman BobCad-Cam 2 09-21-2006 07:10 AM
Confused! which rack and pinion to choose? kanankeban CNC Plasma and Waterjet Machines 3 04-21-2006 03:47 PM
Can v9 save geometry as a .dxf or .dwg? badRandle Mastercam 2 06-03-2003 01:33 PM
