Old 08-09-2004, 12:41 AM
Cold Fusion is on a distinguished road
1/4 Carbide Aluminum Feeds?
Need some help. My aluminum machining success is not too great at the moment and I know it's my feeds/DOC. I'm using 1/4 2flt carbides with depths ranging from 1/4 to 1/2 in 6061 T6. Could someone give me a good starting point? Speed would be nice but the most important thing is to just have one cycle with no surprises
Proud owner of a Series II Bridgeport.
Old 08-09-2004, 12:52 AM
nervis1 is on a distinguished road
http://www.tooltech1.com/
At the bottom on the left there is a feed and speed calc. Get a copy of machinery handbook too, there is a great section on speed and feed with all of the calculations. Keep in mind that machine HP has to be factored in at some point if you want to kick the feeds / speeds up in aluminum.
Old 08-09-2004, 01:33 AM
Dan S's Avatar
Mad scientist
Dan S is on a distinguished road
CF
You might want to try going to http://www.niagaracutter.com and visit this page http://www.niagaracutter.com/techinf..._mat/6061.html this all the information you should need.
Hope this helps.
Dan Sherman
Old 08-09-2004, 09:59 AM
Gold Member
Ken_Shea is on a distinguished road
Andrew I sympathize with you, I am just beginning to get a grip on the feeds/speeds/doc thing, I try to be conservative since I am not in a production mode though. You did not mention what problems you are having but I have used a load per flute of .0015 with a .125 DOC and 3900rpm in 6061 for a .250 2flute carbide end mill.
Here is a very useful free download if you do not already have it, he is a very nice guy and very helpful as well, spend a little time learning the program and it is quite easy to follow. Specs for drilling, tapping, milling, facing/ reaming etc.
ME Consultant 2.0
http://mrainey.freeservers.com/
Ken
How strong? (Linear rails, aluminum structure) WoodSnarfer Mechanical Calculations/Engineering Design 13 07-15-2005 12:29 PM
CNC Aluminum studysession General Metal Working Machines 6 02-12-2005 10:39 AM
In the same boat...trouble roughing aluminum rc-cellar DIY-CNC Router Table Machines 3 11-21-2004 02:58 PM
aluminum extrusion georgebarr DIY-CNC Router Table Machines 19 11-04-2004 10:43 AM
Can I dry mill Aluminum? UCFMems General Metalwork Discussion 6 07-22-2004 06:30 PM
