Old 03-25-2008, 04:46 AM
*Registered*
erdemkaraman is on a distinguished road
MODAL IS OUT OF G80 ERROR
Hi, please help me.
We have FANUC series 31i control unit and manual guide i program.
An alarm occurs between two drill cycles at this control unit. Simulation is working without error but we push the cycle start button , machine is alarm occurs. Alarm is 3572 Modal is out of G80. How is correct this error?
Old 03-25-2008, 06:52 AM
JDenyer232 is on a distinguished road
Originally Posted by erdemkaraman View Post
Hi, please help me.
Do you have a G80 in there between the cycles? You should. Are you using canned cycles or manual guide i drilling? Either way there needs to be a G80 in there between the seperate cycles, G80 is canned cycle cancel by the way. Hope this helps.
Old 03-25-2008, 07:01 AM
*Registered*
I am using manual guide i drilling cycles. Yes i did. I put G80 code between the cycles but it occurs
Old 03-25-2008, 08:05 AM
Go towards the end of your program and run the simulation from there, the idea is that you wan't to get your cancel codes read. Manual guide I can be very picky if you stop somewhere in the middle of a program and then try to restart at a different point. You can also try putting this in, in mdi mode and run it. G80 G90 G40 G49 G94. Then call your prog into memory and try running it. Post your prog here and I can take a look at it for ya.
Old 03-25-2008, 08:10 AM
Also put a note where it hangs up on ya, it will make it easier for me to troubleshoot it.
Non-modal G00,G01...G03 cncuser1 Mastercam 4 05-30-2007 01:39 PM
changing values to non modal mmurning Post Processors for MC 5 12-06-2006 07:11 PM
Mach2 G02, G03 Modal? miljnor Mach Software (ArtSoft software) 3 04-27-2005 10:06 PM
Post Processor (ISO G-Code - Non Modal) CNCadmin Carken Products (Deskam, DeskCNC etc) 1 01-29-2005 07:32 AM
Coordinates modal and / for rapids HuFlungDung OneCNC 6 04-04-2003 09:42 PM
